Knocking noise
Old Aug 25, 2010 | 01:52 AM
gankda59's Avatar
Car Info: 04 STI
Knocking noise
I have a 04 STI motor started to make a knocking noise anyone know a good shop that knows how to work on our cars or if u know anyone the can. Was thinking about doing a motor swap or something. Let me know please. Thanks.
Old Aug 29, 2010 | 09:44 AM
subiracer06's Avatar
Car Info: impreza wrx sti 2004
need to know a little more info please... how many miles? does the knocking get worse throught the RPMs? under load? GST is the best around here for quality work.
just a heads up mine had 70k on it and my oil pickup cracked causing oil starvation and total motor failure. if you let it go unckecked for too long your most likely going to need a rebuild due to bearing failure and metal shavings errwear. i put the killer B motorsports oil pickup tube in mine so i can never have this issue again.
my symptoms were knocking, oil usage, loss of power, low oil pressure. what are your syptoms?
Old Aug 29, 2010 | 01:42 PM
soggynoodles's Avatar
Check the Hawaii section here. There are a few shops on the island that can help
jwhitey
Aug 4, 2007 12:27 PM
Lucky7w
Jun 17, 2007 10:56 PM
tailspinz
22
Sep 23, 2004 11:38 PM
spankmeplz700
13
May 2, 2004 04:22 PM
Fast turbo 20
17
May 8, 2003 11:28 AM
