K&N air filters are NOT A BENEFICIAL MOD!
Originally Posted by testes1010
The stock air box IS a CAI.
My reasoning for why a CAI > SRI is because the IAT(Inlet Air Temp Sensor) in the MAF is one of the factors for adjusting/advancing timing. Colder air more timing. (Although its a ****-poor location for it, it should be in the Throttle body after the IC or have 2 for calculating turbo/ic efficiency.)
Note: No aftermarket CAI or SRI is good for a stock WRX.
First off I did read the whole acticle. This one chart (attached), at least how I read it, conterdicts what you say about the K&N flow being the worst.
I read this as Restriction, In. of H20 across the filter(Actual pressure drop across the filter) as CFM increases. This chart alone shows that the K&N flows the best. I may have misinterpreted it but thats how I read it.
Jeremy
Jeremy
Makes sense, everything is a trade off.
I got sick of the debate and bought an HKS three layer foam drop in ~ at least there is no oil...
Oh, and after running a Green an STI (SPT Version) and a K&N... the HKS was the only one I could feel ANY difference with. Better throttle response and easier revving high in the range (above 4 grand) then the others. This was with my mechanic riding and driving the car with each filter as a second opinion.
im happy with my STi filter, personally i think its better than my stupid airhog and it filters better too... i think im gonna buy the HKS just to test it out to see if i like it..its only like $35
atleast the good thing with air filters are that its really easy to switch out and make runs with different ones
yeah, its not oiled, however i believe it still leans out the air/fuel ratio, so youd have to get a custom tune
drop ins are the way to go, and i say stick with the STi filter element
remember ALL filters actually filter BETTER (ie trap smaller diameter particulate matter) as they age.
i have run a k+n on my car since the month after i bought it. i resist the urge to overclean it, due to the above point. as a result i clean it once a year.
a good friend of mine picked up 1mph in a 1320 by removing an oem wrx air filter element entirely from the box. i have no corresponding data for any other filter though.
Car Info: '08 WRB SG model D
Originally Posted by Cody8675309
The quote that really took me by surprise was this:
"Compared to the AC, the K&N “plugged up” nearly 3 times faster, passed 18 times more dirt and captured 37% less dirt."
Stevesdub
Jul 26, 2006 06:07 PM
suba-rulez
Jul 16, 2006 04:35 PM
