K&N air filters are NOT A BENEFICIAL MOD!
Originally Posted by thevanitygroup
^You both havent read the entire post.
The K&N flow rates are absolutly terrible for a filter that cant catch anything smaller than a oak tree. So what have we concluded from todays lesson?
1. K&N flows WORSE than almost any reputable filter available.
2. K&N filters WORSE than almost any reputable filter available.
Basically tests prove it should be at the bottom of your lists when buy a filter. See this is exactly what I mean about this topic. Even though the facts are in people still want to find a reason to spend $50+ or more on a K&N even after they are proven crap.
stay informed.
stay informed.
As for the test, it is a big eye opener. I got my K&N for free and I use the K&N cleaning kit to keep it cleaned and properly oiled. I may just go back to OEM filters (at least for offroading) after reading the findings.
The quote that really took me by surprise was this:
"Compared to the AC, the K&N “plugged up” nearly 3 times faster, passed 18 times more dirt and captured 37% less dirt."
Down to two myself...
Originally Posted by pablo_her
so i should keep my stock box and filter. i probably did read this whole post right but is there any good after market filters for my stock box?
Originally Posted by TheScoobyMedic
what about the STi filter element from Subaru, what is that made out of??
Scroll down to the air filters and there is a picture of the three OEM filters!
http://endwrench.com/images/pdfs/FilterFeb06EW.pdf
yah i know, i have all the issues, but it doesnt say what its made of, is it oiled
well i guess it doesnt matter, the STi element is FROM subaru, soooo its gotta be legit haha word?
I think the funniest thing is when I did go to order a K&N air filter, the number that matches the 06 WRX was not even the right size. I have recently purchsed a typhoon system and will try to see what gains, losses it produces on a dyno and will repost then.
In my noob opinion...
the typhoon intake allows for more air to flow into the motor so I am not sure how that is a bad thing.
and my question is that the filter that was tested was specific for a Ford diesel, which is a different set up than the typhoon is.
if oil is bad for the MAF, why is the stock filter oiled and how is that one not bad. I guess I should reread again, but I just dont get it.
I was wondering about that too..
I have a Green Filter, similar idea to the K&N but more pleats and much better materials.
http://www.scoobymods.com/forums/showthread.php?t=2271
I've had Blackstone Oil analysis done a few times and my Silicon levels are normal showing that the filter is doing it's job properly.
http://www.scoobymods.com/forums/showthread.php?t=4718
Green Filter suggests cleaning it more often than the K&N. I do mine a few times a year. One thing about any oiled filter is the risk of over oiling. I like to oil mine and then let the filter sit overnight on some shop rags. This wicks out any excess oil. That works for me.
Thanks for the advice. I think I am going to be calling the shop that will be doing my tune for the exhaust and see what they reccomend.
3. COLD AIR INTAKES ARE FOR THE RETARDED. Why? Because your cold air is going to go straight through your turbo and immediatly be changed to the same temp that the inside of your turbo is. Regardless if it comes in at 10 degrees cooler is going out at the exact same temp.
Stay informed.
Stay informed.
My reasoning for why a CAI > SRI is because the IAT(Inlet Air Temp Sensor) in the MAF is one of the factors for adjusting/advancing timing. Colder air more timing. (Although its a ****-poor location for it, it should be in the Throttle body after the IC or have 2 for calculating turbo/ic efficiency.)
Note: No aftermarket CAI or SRI is good for a stock WRX.
I read this as Restriction, In. of H20 across the filter(Actual pressure drop across the filter) as CFM increases. This chart alone shows that the K&N flows the best. I may have misinterpreted it but thats how I read it.
Jeremy
