Intercooler Sprayer
Old Nov 21, 2004 | 12:04 AM
mrl859's Avatar
Intercooler Sprayer
It seems inconceivable to me that the intercooler sprayer on my $30K+ '05 STI does not have an auto function, like the standard EVO (MR excluded). Even the stage 2 upgrade (w/toys) on my SRT-4 has an auto sprayer. It should be built into the engine controller logic based on rpm, engine load, throttle position, etc. Is there an INEXPENSIVE solution?
Old Nov 21, 2004 | 01:12 AM
dan2304k's Avatar
Car Info: '07 FXT Sport / '96 STiL
I just have my girlfriend reach over and push it since her head is down there anyway. =)
Seriously though, you can get a pressure or thermal switch pretty cheap. Hook up the pressure switch the same way you hook up a boot gauge. iirc, you can get an adjustable one for about $30 and just dial in the pressure you want to activate it. You could also build a circuit from a $10 programmable microcontroller to activate it at a specific RPM range.
Thermal switch might be the best bet, should also be pretty inexpensive. I'd consider a microcontroller and two temperature sensors and have it activate the water spray when it sees a big enough difference between intercooler temp and ambient air temp. This way you could also add some code that would prevent it from running indefinitely and emptying the water tank.
Old Nov 21, 2004 | 07:10 AM
Magish's Avatar
Old Nov 21, 2004 | 10:44 AM
mrl859's Avatar
Thumbs down
"I just have my girlfriend reach over and push it since her head is down there anyway. =)"
That's great. But I don't think she'll do that for me.
Old Nov 22, 2004 | 04:14 PM
FW Motorsports's Avatar
iClub Silver Vendor
Car Info: 2005 LGT wagon
She does for me...sorry, had to say it.
But back to the question at hand. I have an adjustable pressure switch from an '84 Saab Turbo that I'll be using for my auto setup...I'll post pics later.
Old Nov 23, 2004 | 09:44 AM
BLITZSTI's Avatar
Car Info: .
save yourself the trouble and get this
http://www.intakeone.com/Pivot/Piv_WSC.html
or this
Attached Thumbnails Intercooler Sprayer-index_wsc_big.gif   Intercooler Sprayer-rotorworks_1816_641053.jpg
Blue_Rexer
May 5, 2004 09:24 AM
silver satin
Jul 5, 2003 02:24 PM
B18c1
Jan 23, 2003 03:02 AM
slvrwrx02
Wanted
Dec 20, 2002 05:32 PM
