IHI VF37 turbo TWIN SCROLL design specifications?
Old Aug 2, 2004 | 07:26 PM
The second picture is the turbine and exhaust housing. The third is the uppipe.
Old Aug 2, 2004 | 08:31 PM
Mister 2's Avatar
Nope, the third also a picture of the exhaust housing.
Old Aug 2, 2004 | 08:34 PM
Whoops, you're right... I saw the flange shape but didn't notice the rest of the turbo behind it.
Old Aug 3, 2004 | 12:47 AM
nic3krnnamja83's Avatar
so would i find any gains from this, ur guys information as always very helpful thanks
Old Aug 3, 2004 | 01:16 AM
If you have a stock turbo, yes. If you have a VF22, only on the low end. If you have a VF30/34, slight peak gains and significantly more mid range torque/ faster spool.
You'd need larger injectors and fuel pump along with the turbo/uppipe/downpipe/header combo from the Spec C, as well as a reflash to keep the ECU from freaking out at the extra low end boost and extra fuel.
Old Aug 3, 2004 | 01:26 AM
i always wanted to ask where i could obtain spec c parts from? any recommended places? thanks Ban. ALso the vf22 is the twin scroll correct?
the run down:
vf22 slight gain but would need supporting mods as listed above
Old Aug 3, 2004 | 01:42 AM
the run down:
They come from Japan. Several vendors here and on nasioc import JDM STi parts. No, the VF22 isn't twin scroll. Only the VF37 and VF40 (JDM Legacy turbo) are.
Old Aug 3, 2004 | 09:37 AM
ROGER that Ban
thanks once again for all your insightful information. hopefully by next i-club track day, eveyrone can see it.
Old Aug 3, 2004 | 11:47 PM
El Supremo's Avatar
There's also the vf36 and PE's entry the PE1825f for twin scroll applications. Someone on the Nasico forum is working with a Garrett GT30R kit too.
Old Aug 5, 2004 | 05:42 AM
Stevied's Avatar
Car Info: 4 wheels
My understanding is that the VF36 is the JDM Spec C twinscroll turbo..
These guys sell them
www.jdmpartstx.com
Old Aug 5, 2004 | 06:07 AM
I think you're right actually. The VF37 is from the Legacy twin scroll setup. Got myself mixed up...
Old May 20, 2005 | 06:28 PM
seb's Avatar
seb
Car Info: subaru RS STI RA V6 combo
the Vf37 is on the JDM Version 8 STI vand STI RA version the VF36 is the one mounted on V8 spec C it`s the ball bearing version...if you are looking for JDM parts and twinscroll turbo...i have some...
s.marquet@videotron.ca
Old May 21, 2005 | 03:03 AM
Long_Travel_WRX's Avatar
Car Info: stock 04 wrx sedan
i havnt seen one make a gross amount of power at leaser here on crappy CA91 i know people who have tried and ended up with an FP turbo ohh lets see the time slip for that 12 sec run
Old May 21, 2005 | 09:22 AM
seb's Avatar
seb
I sold a complete 1700 canadian dollars VF37 with oil pan headers up pipe and all the necessary component s needed and i can have others same price
Personnally i have a version 8 JDM in my car with Vf37 twinscroll and i ran 12.6@110mph stock with 94 octane with Bridgestone RE040 as tire (big ****) no glue on the track and a 65: 35 center diff proportion
