Help on Perrin DP and CEL fix
Old Sep 29, 2006 | 10:12 AM
enzo350's Avatar
Car Info: Loading...
Exclamation Help on Perrin DP and CEL fix
I installed the Perrin DP, got CEL and flashing cruise control, blah blah...I did a search, but nothing on this issue:
I tried to install the mechanical CEL fix on the O2 sensor on the Perrin DP but there is no way the CEL fix will fit between the DP and the underneath of the car. The space is just to narrow.
Am I missing something? Am I suppose to install the fix in another location?
Help!
Old Sep 29, 2006 | 10:41 AM
lburrrna's Avatar
you running any Engine Managment?
Old Sep 29, 2006 | 10:44 AM
enzo350's Avatar
Nope, I'm not.
Old Sep 29, 2006 | 10:50 AM
enzo350's Avatar
Old Sep 29, 2006 | 11:53 AM
dubwrx's Avatar
Car Info: 2004 STi
the subaru is known to overboost when a downpipe is installed. that is what happened. the car will run fine after the CEL. jsut the annoying flash of your cruise control light.
you will need to find someone with a code reader and have it cleared. i believe it is code 422xxx something..
you will eventually need to get an engine management. either Ecutek or Cobb.
good luck
Jeremy
Old Sep 29, 2006 | 12:01 PM
enzo350's Avatar
good luck
Jeremy
So I can't do the mechanical CEL fix on a Perrin DP?
http://www.scoobymods.com/forums/showthread.php?t=5468
http://forums.nasioc.com/forums/show...96&postcount=7
https://www.i-club.com/forums/showth...&postid=285412
black02
Mar 11, 2006 11:13 PM
t3ch9
Apr 10, 2005 07:24 AM
dashiet
Oct 15, 2004 10:31 AM
MARKSTI
Apr 2, 2004 07:21 AM
esracer
Mar 16, 2004 11:56 AM
