gauge problem? or tune? overboost?
Old Feb 25, 2009 | 09:13 PM
anthonyfur's Avatar
Car Info: 04 JBP STi
so its been like this for a while now, wen i boost it, WOT, my boost gauge read passed my target 16 or 18psi depends wat map i have on it, it just keeps goin to 20psi almost 25. it doesnt spike to those numbers just keeps goin up. and no cels are thrown after. ????
so is it my boost gauge?
or is my tune off?
over boost?
i think this might have caused my cracked ringland.
mods:
-EJ257 swap
-2.0 heads, ported and polished
-Titanium valve springs / retainers
-Crower 264 cams
-JDM V8 intake manifold (TGVless)
-STi V8 TMIC
-STi 565cc injectors
-Walbro 255lph fuel pump
-VF34 turbo
-Injen V2 CAI
-Perrin turbo inlet
-Perrin Pulleys
-Cusco oil catch can
-HKS circle earth grounding kit
-oSUNo auto hyper voltage grounding kit
-Helix catless bellmouth DP
-M2 catless UP
-invidia G200
-Cobb AP V.1 tuned by Tim Baily at surgeline tuning
Old Mar 14, 2009 | 04:47 AM
blueTR_808's Avatar
Car Info: 06 WRX
You should try pulling some logs just to double check. It also could be boost creep.
Old Mar 14, 2009 | 08:41 PM
PikkaGTR's Avatar
sounds like boost creep to me
check the logs on the AP
Old Jul 9, 2009 | 07:55 AM
Prosport Gauges's Avatar
Car Info: 2006 STI~ 504HP
Are you using a mechanical or electrical Boost gauge? What brand is it ?
Old Jul 9, 2009 | 11:27 AM
anthonyfur's Avatar
boost gauge is defi boost gauge, the green lit up ones.
Old Jul 10, 2009 | 04:07 PM
C89ZX7R's Avatar
banned
Car Info: 2004 STi
Edited because everyone thinks my replies are a type of trolling!
Old Jul 10, 2009 | 06:52 PM
04caliwrx's Avatar
electric
if he is tuned by tim I'm gonna have to go with aelectric boost gauge.
Old Jul 11, 2009 | 05:40 AM
Defi only makes electric..
So you have a manual boost controller set to 18 ?
Old Jul 11, 2009 | 11:40 AM
anthonyfur's Avatar
no i have no manual boost controller..
yes i have a defi electric boost gauge
my tunes map is set at 18psi
Old Jul 12, 2009 | 04:38 AM
How about the gauge, does it start out at 0 ? with key on engine off where does the needle rest at ?
Old Jul 14, 2009 | 11:37 AM
anthonyfur's Avatar
i believe it starts below 0 but i think all the numbers below 0 is for vacuum?? and when engine off its at 0
but oil press is all the way down and it makes a really annoying beep sound until i turn the car on again or take the key out fully.
Old Jul 14, 2009 | 12:06 PM
How about you call us so we can help you over the phone
727-572-9011
04GG
Jan 30, 2012 05:20 PM
da_coolest
Sep 29, 2011 03:50 AM
sroperformance
Engine and Drivetrain
Oct 27, 2005 04:52 PM
Toiletbrush
Jul 14, 2005 03:19 AM
twizzwrx
Dec 20, 2002 02:34 PM
