fuel pressure help ASAP!!!
Old Jun 17, 2008 | 04:46 PM
AWDnutjob's Avatar
Car Info: 2004 PSM STi
i hope someone can help me here...... i drive an 06 wrx..... and my fuel pressure regulator went to sh*t...... ( subaru told me i should be seeing 30-38psi form idle to wot, and i am seeing 50-58 )
Here is the problem...... kragen,autozone, napa, etc. do not carry newones due to the car being so new..... the dealer wants way too much ( way broke right now )
I can get one off of a 2005 and older form the wrecker for $25 does anyone know what pressure they run and if they would work on a stock non tuned wrx .... even if it was only on the car for say a week so i can pass smog....... if anyone can help please drop me a PM
thanks in advance.....
S.Hood
Old Jun 17, 2008 | 05:20 PM
FW Motorsports's Avatar
iClub Silver Vendor
Car Info: 2005 LGT wagon
Why won't warranty cover this failure?
Old Jun 17, 2008 | 05:44 PM
AWDnutjob's Avatar
dealer knows about my mods... they are sneaky that way ahhaha..... the only reason i knew it failed was because i had to smog the car.... so i put it back to stock..... and it failed miserably..... so i figured why not see if subaru will fix it........ hells no, they flagged me for everything still on the car ( clutch, suspension, mud flaps) and then proceeded to tell me about the mods they figured were on the car at one time ( charging me for that ) and then told me the new about the regulator, and that it would be $120 for the part, ( none in stock either ) plus install........ and i am going through hard times, as alot of peeps are... so i am looking for any help,, rather begging..... i called subaru and they told me they owuld have a tech call me..... that was a week ago... and i have called back.... maita subie sucks for help....mike at gst had no idea what the pressure should be, suggested aftermarket fpr, but thet will fail visual on smog.... i was thinking of putting an sti one on, but that might flow too much for smog once again maybe i shold just move to a non-smog state haha....
Old Jun 17, 2008 | 05:48 PM
AWDnutjob's Avatar
i will stick with this section....for paul haha
Old Jun 18, 2008 | 05:58 PM
AWDnutjob's Avatar
well, sinc ei couldnt get any help..... i bit the bullet and i went to a subaru recyler... pulle doff a 2003 FPR and what do you know..... same denso part number on front... funnt how subaru will tell you they have different FPR's so hopefully this fixes my problem.. if not....... subaru can have the car back... i am done haha
AWDnutjob
Jun 17, 2008 05:51 PM
suby_dude
Feb 12, 2008 01:28 PM
cdaddy06sti
Aug 4, 2007 05:10 PM
ImprezaRSX
Feb 2, 2004 09:43 PM
silverscooby
Feb 18, 2003 07:29 PM
Top
