Flashing Cruise Control light and CEL from intake?
Old Mar 28, 2004 | 07:23 PM
thebankman's Avatar
Car Info: subaru
You should probably check out the Sticky post at the top of this STI forum. The CELs and flashing cruise control usually mean boost cut off, due to a whole number of things from turbo back exhausts being added or intakes added. Read that post, it's due to the turbo design on the Sti. Good luck
Old Mar 29, 2004 | 12:33 AM
There's nothing wrong with your stock intake. Changing the intake out (as it says repeatedly in the EJ20 forum sticky) can dramatically mess with the MAF sensor readings. Different individual intakes of the same type can even affect the same car differently. Meaning, 2 guys can have the same car and same type of intake with different results.
Racerkid
May 29, 2012 06:16 PM
iGoTsBLu06sTR
Jan 21, 2008 06:47 PM
kyle_RS
Jan 7, 2007 04:20 PM
06scooby
Oct 15, 2006 10:11 AM
wimprezax06
Mar 26, 2006 09:04 PM
