EGT Bung Location
Old Jul 28, 2004 | 02:26 PM
48mpg's Avatar
Car Info: '04 STi
EGT Bung Location
Where should i put the EGT Bung at to get a good reading?
Up stream or downstream of the turbo, i'm thinking downstream cause you wouldn't want the heat from the turbo to affect the reading, but i'm hoping dwonstream cause i'm gonna have the dp off anyways
Old Jul 28, 2004 | 03:14 PM
RoadSpike's Avatar
factory egt is on th up pipe i believe
Old Jul 28, 2004 | 11:02 PM
Mach5WRX's Avatar
Angry Dan
Car Info: 05 Evo VIII
A lot of people who install EGT gauges take off their exhaust manifold and drill/tap a hole in it for the probe. The exact placement of this probe is a HOT topic! Do a search.....you will run across threads discussing it.
Old Jul 29, 2004 | 10:41 AM
gpatmac's Avatar
I vote #3.
Old Jul 29, 2004 | 03:07 PM
Mach5WRX's Avatar
Angry Dan
Originally Posted by gpatmac
I vote #3.
Me too
Old Jul 29, 2004 | 06:34 PM
Onizuka's Avatar
Car Info: 04 STi
I haven't done mine yet but I've been told by several other members that you should tap the manifold for the best reading.
-GDO
Old Jul 30, 2004 | 11:05 AM
48mpg's Avatar
Car Info: '04 STi
yeah, thats what i thought too,
off with the manifold it is
also, i got a greedy EGT, should the bung be welded in place or should a good drill and tap job do
Old Jul 30, 2004 | 03:23 PM
Mach5WRX's Avatar
Angry Dan
drill and tap
Old Aug 3, 2004 | 04:10 PM
48mpg's Avatar
Car Info: '04 STi
thanks guys
also, i'm taking off the turbo anyways to have thewastegate ported, could i just drill and tap the manifold while its still on the car and then try to start it to blow out the shavings,
basically i'm tryin to take off as little as possible, plus i don't want to run the risk of possibly damaging any other gaskets, if i dont need too
atc5
Jan 5, 2005 07:34 PM
RoadRageDev
Wanted
Nov 1, 2004 11:26 PM
wang
22
May 21, 2004 03:20 PM
turbeau
Jan 3, 2004 08:48 AM
iTSaWRX!
Aug 29, 2003 05:04 PM
