which dp is better?
Old Sep 24, 2007 | 05:41 PM
  #31
adobeamd's Avatar
Car Info: 2003 WRX
im thinking about a megan how are peoples feelings about those
Old Sep 24, 2007 | 05:48 PM
  #32
VIBEELEVEN's Avatar
Car Info: 03 WRX
Depends on goals and budget, do you want to keep a cat? Do you want to sped alot of sheckles? Just don't buy the HKS. Go with a divorced wastegate or a bellmouth. I've had a helix and a stromung. I opted for the stromung because I wanted to keep a cat to negate the "fuzz" factor.
Old Sep 24, 2007 | 05:50 PM
  #33
VIBEELEVEN's Avatar
Car Info: 03 WRX
Originally Posted by cordeezle06sti
man i just ordered a hks catless... shiot.. dam soO i already have hks cat-back 3 in. im guessin ill go with a cobb, maybe a perrin!?! sun of ah
Homework is a biach, but it'll save you from making poor choices, hock that piece of **** on ebay asap, or see if you can cancel your order.
Old Sep 27, 2007 | 03:14 AM
  #34
04silverWRXSTI's Avatar
Car Info: 2008 Mercedes E350
Whats the difference between a divorced wastegate downpipe and bellmouth and which is more beneficial?
Old Sep 27, 2007 | 03:00 PM
  #35
illusion's Avatar
Car Info: '09 accord, '14 2 seater chevy
Originally Posted by rmanthon
Here's a lil blurb from Daddy's post on WRXF.
More info on the site.
http://www.daddysscp.com
We haven't dropped an announcment in quite a while so we'll be making up for lost time over the course of this weekend with serveral of them. We'll start it all off with one of the biggest announcement we've every made. First off I'll ramble a little by saying a good portion of our exhaust parts we sell end up in California. Probably no surprise there since a lot of the sport compact scene is based there. Knowing that a large chunck of our business originates from there clearly has some influence on the products MadDad™ brings to market. Things like the MadDad Whisper for instance...which by the way passed a California Db test at 94.5 db on a WRX that was bone catless. But that's for another thread. So on with our announcement and you Cali boyz and girls rejoice.
MadDad™ Metal CARB Bellmouth Downpipe
The Cat is a CARB certified OEM replacement, the DP is still illegal. As was said, to be legal your OEM cats must be damaged, non working, or over 8 years old. You also must retain the same number of original cats AND piping diameter, in our case 2 (or 3 if you count those of us with an uppipe cat).
Here's the part of that blurb you left out
This will be the first ever Subaru performance downpipe offered with a CARB certified Metal Substrate cat. Just to be clear here the downpipe as a whole does not have a CARB number, however the metal substrate cat that will clearly be seen(positioned down low in the last cat spot) will have it's number clearly visible and this alone will be reason for many to rejoice.
Thus, still illegal. I'm willing to bet he swapped out the old metal substrate cat he used to use for the magnaflow(carsound) CARB certified one, I doubt Rich would spend the money and go through the hassle of getting something CARB certified. My previous V6 accord was the guinea pig for the Comptech CARB certification for the V6 accord supercharger, and BOY was that a pain in the ****, and Comptech moves a hell of a lot faster than Rich does.
I love Rich's workmanship, and work ethic, but his prices leave some to be desired as does the performance. I've gone through a maddad V1 catted and V2 catted and had enough headaches to last a lifetime. With the V1 I ran the OTS stg2 cobb map and it was ok. I upgraded to the V2 and halfback(one of the first) then I upgraded to a VF34 and decided it was protune time. Mike had a hell of a time tuning it(read 8 hours on the dyno and still only 232hp out of a VF34). Anything over 5k rpms the exhaust was so turbulent he couldn't get a stable AFR reading from the wideband and the motor was acting like it was restricted. I ended up ditching the stock axle back and going to a borla. Better but still awful, up to 238whp on the heartbreaker. I then went to a helix bellmouth, readings all the way to redline and the engine came alive.. a hair over 250whp.. I'm not sure if its the cat design or how the divorced pipe bypasses the cat, but the V2 was not a happy camper with a VF34 blowing through it. Stg 2 it was ok, but with something blowing a bit harder I'd say to stay away.
As for the thread, bellmouth, divorced, 6 one way half dozen the other. If you don't want stinky at stoplight get a catted one, running 10.5:1 at high RPMs is more than the cat can handle and you'll still be stinky running WOT.
As for me, I'm content with the Helix Catted, it does what its supposed to do.
Old Oct 15, 2007 | 03:19 PM
  #36
gripordie's Avatar
Car Info: 2007 wrx
Ebay Ftw
Old Oct 16, 2007 | 10:08 AM
  #37
klenboy's Avatar
The HKS DP appears to be ok with EWG setups.
Old Oct 16, 2007 | 10:36 PM
  #38
wimprezax06's Avatar
Car Info: WRX --> RX-8--〉E93
then its time for you to try a different kind =]
Old Nov 5, 2007 | 01:08 PM
  #39
Traxamillion's Avatar
Car Info: nothing
perrin makes the best IMO
Old Nov 7, 2007 | 07:11 AM
  #40
SBR Oliver's Avatar
Former Sponsor
Car Info: 2004 STI
Go with the Perrin
Old Nov 7, 2007 | 06:03 PM
  #41
subie OCD's Avatar
Car Info: 04 STi
Write down all the names and put them in a hat, then draw.
Or visit some subaru meets and pick the one that sounds best to you.
Or talk to your local tuner and find out what they work with best.
jdubb
Feb 23, 2003 03:33 PM
BlackDubbaUREks
Feb 17, 2003 12:50 PM
wrxed indian
Feb 10, 2003 06:21 PM
wrxed indian
Jan 14, 2003 07:13 AM
subaruhacker
Nov 26, 2002 11:24 PM
