downpipe in Cali
Old Oct 23, 2009 | 10:08 PM
choiboi's Avatar
Car Info: 06 WRX TR Stage 2
downpipe in Cali
So i live in Cali and currently stage 1. Wanna go stage 2 now, which means i need a downpipe. So i was set on getting a catted downpipe, but i also hear that the catted dp prob won't pass smog as well. Either way, i guess i was goin to switch back to my stock if i need to smog. So my quesiton is, should i get a catted or catless dp in Cali? Is catted dp worth it even if i will change to stock for a smog?
Catted:
Pros: catted, quieter, May pass smog (but i will change to stock to make sure)
Cons: expensive, quiet?
Cattless:
Pros: Better flow = more power, louder?, cheaper
Cons: Cattless, definitely won't pass smog, illegal, louder?
What you guys think? I've thought about it myself, but i need other's ppls point of view! Help me decide!
Old Oct 23, 2009 | 11:32 PM
subi4justin's Avatar
Car Info: 2015 SWP WRX
I think you should get cattless. There are a ton of guys running around the bay with full cattless DP's. It is louder for sure and it will get the attention of cops a lot more, but if your ok with getting pulled over then go for it. Ive only gotten two noisy muffler exhaust tickets, but im ok with it.
Old Oct 23, 2009 | 11:45 PM
4eatme's Avatar
Car Info: 2002 WRB WRX
I'm catted with hi flow helix.
Before I had the dp on I got pulled over by chp no sooner than 2 weeks after I installed my cheepy SRS. Since then I've had my silencer in (1 year) and been stage 1. I recently bought a catless but decided against it and went with a hi flow cat, just to keep things quiet. I just don't need the attention and want to avoid being pulled over at all costs.
When I put the hi flow dp on, it didn't get much louder, just deeper and had more of a rumble (with major turbo spoolage audible). I've kept the silencer on, because I'm sure without it, it would be deafening. Not to mention MAJOR IMPROVEMENT after the tune going from stage 1 to 2. BTW, check out my thread I started... Has a few opinions you might be interested in reading.
https://www.i-club.com/forums/bay-area-15/all-catless-downpipe-tbe-owners-206862/
Old Oct 23, 2009 | 11:47 PM
blkwagon's Avatar
Car Info: 2002 sedan sti swap high on meth
cated still won pass smog in cali. it will jkeep the raw fuel smell down tho
Old Oct 24, 2009 | 12:47 AM
KrAzYkld's Avatar
Car Info: 1998 M3, 2016 WRX
i say just go catless with a quiet catback because the catted downpipe is still illegal. just my 0.02
Old Oct 24, 2009 | 09:57 AM
chochocho's Avatar
Car Info: 91 legacy, 87 mr2, 17 forester xt
catted downpipe should pass the actual smog test.
what it would not pass is visual.
LifePlaza
Nov 23, 2005 01:36 PM
stepinrazor
Mar 6, 2003 12:05 PM
samurai
Feb 19, 2003 05:22 PM
kuruptONE
Subaru OEM Parts For Sale
Feb 4, 2003 12:12 AM
E30M3Dreams
Nov 27, 2002 09:12 AM
