does anyone know the VF36 turbo specs?
Old Oct 24, 2006 | 01:50 PM
azn_ryder02's Avatar
Car Info: 2007 Satin White Pearl STi
tid bit: the VF36 turbo is the twinscroll turbo that comes stock on the STi spec-C i was wondering if anybody had the specs or know anything about this turbo in terms of A/R and flow rates and/or comparible size to the stock VF39 and compared to other twin scrolls like the APS tsr70
im very interested in this turbo b/c ive heard very good things about twinscrolls but most of the after market ones seem kinda big
also the specs of the vf39 would be appreciated too thanx
Old Oct 27, 2006 | 11:55 PM
Krinkov's Avatar
the VF36/37 compare almost directly to the VF30/34, they use he same compressor and turbine AR, the VF37 is sleave bearing like the VF30 and the 36 is roller bearing like the 34, the 36 also suposedly uses a lighter titanium turbine and shaft as well. All in all they wont flow anymore or make any more power than the single scroll 30/34, and while twin scroll is always benificial, on the 2.5 I have not seen any worthwhile difference in spool running these twin scroll versions compared to he single scrolls, these are already pretty small turbos!
the VF30/34 is rated at 435cfm at 1/bar dont have numbers for the 39, but its just a bit less
Old Nov 18, 2006 | 08:49 PM
other twin scrolls
are other twinscrolls other than aps tsr70 turbo thats larger than stock??
Old Nov 19, 2006 | 03:33 AM
Krinkov's Avatar
the aps TSR 70 is basically a twin scroll Garrett GT seriesd turbo, I dpnt know the exact specs but it looks to be about GT35 sized. If your not married to the idea of having the APS name brand tacked onto a Garrett turbo, you can get any of those Garrett GT series turbos with a twin-scroll turbine housing from ATP for alot less $$$
http://www.atpturbo.com/
Old Nov 19, 2006 | 09:21 PM
thanx. how big is the gt30 compared to say a 20g? is there smaller twin scrolls available?? sorry, i appreciate the info dont have much experience w/ turbos. the aps guy said that the tsr70 hits boost at 3500 is that possible??
Old Nov 21, 2006 | 12:26 AM
Krinkov's Avatar
the GT30R is much bigger than either of the 20Gs, the GT3071 is a bit smaller but still bigger. TD06 20G should be around GT2871R size, though I dont think they make a twin scroll for those, though a GT2871R would already spool pretty doan quick enough on a 2.5
Im not sure what size compressor wheel the APS one uses, but from what I hear its comparable to a GT35, which is way bigger than I like but thats just my pov.
and the "hits boost at 3500" is completely irrelevent. What boost? 1 psi? 14.7 psi? 20 psi? And regarless keep in mind that trying to measure spool up by what RPM a turbo hits xx boost is useless, since what we experience as lag is the amount of TIME not rpm it takes for turbo to spool up, you can have a small turbo and large turbo both hit say 15psi at 3500 RPM, but the larger turbo will take more time (lag) to get up to that 3500RPM/15psi level.
chochocho
Feb 24, 2012 04:09 PM
calisti
Subaru OEM Parts For Sale
Apr 22, 2009 12:16 AM
outcast
Apr 24, 2006 09:17 PM
typer_126
Oct 31, 2004 04:01 PM
typer_126
Wanted
Oct 31, 2004 08:08 AM
