Cracked Piston
Old Jan 31, 2014 | 06:52 PM
FearNoEvo's Avatar
Car Info: 2007 WRX Limited
Cracked Piston
Is a cracked piston common on a 07 WRX with 90k? CEL came on, took it to the dealership, told me it was misfiring, they thought it was a burnt valve, so they did a leak down test, 2 cylinders are leaking so now they think it's the pistons. Need help.
Old Jan 31, 2014 | 10:31 PM
Javirex23's Avatar
Car Info: 07lmtd 6spd wrx eq tuned
welcome to the club. mine happened at around 70k, but my car still drives fine (i don't drive it hard) i drive about 10-12 miles a day…my advice, is depending on your budget you can either buy an oem short block, build yours up, or jdmswap
Old Feb 1, 2014 | 08:52 AM
FearNoEvo's Avatar
I actually bought an extended warranty so it sounds like they are going to put in a short block. Why the need for the whole short block and not just pistons?
Old Feb 12, 2014 | 07:49 AM
strider327's Avatar
Car Info: 2005 WRX
If your having someone else do the work, it would be more cost effective to just buy a new shortblock versus paying for the labor replace and install new pistons. Also note the fact that when the tear down happens, you don't know if the cylinder walls are messed up or not, etc.
Old Feb 13, 2014 | 08:49 PM
FearNoEvo's Avatar
They are f ed up like a home made radio. Now it's just burnt valves.
edzwrx
May 17, 2012 12:17 AM
cuscogdb
May 10, 2012 02:56 PM
Teddy
Aug 7, 2004 12:35 PM
imagineice
Jan 19, 2003 11:31 AM
