cel help please
Old Apr 28, 2005 | 10:53 AM
isr96's Avatar
Car Info: 2007 suzuki GSX-R600
cel help please
I installed a downpipe on my sti yesterday and now I am throwing the cel P0420 which is catalyst system efficiency below threshold. Can anyone give me a better explanation of what that means. I also have the cobb accessport and I believe there stage 2 map was suppose to remove 2 certain cel but I don't remember which one and I do not have access to a computer to search. I am posting this on my cell phone btw. I am using the stage 2 91 oct map on the ap btw. Any help appreciated.
Old Apr 28, 2005 | 02:00 PM
isr96's Avatar
Slow day on I club or what? Nobody can help?
Old Apr 28, 2005 | 03:26 PM
isr96's Avatar
Ok so I found out that the stage 2 map is suppose to remove cel code P0420 which is what I am throwing. Anyone know why this cel is showing up even though I have the stage 2 map reflashed on my car
Old Apr 28, 2005 | 03:36 PM
ShiroStee's Avatar
Car Info: 05 sti
no cel fix?
Old Apr 28, 2005 | 04:36 PM
isr96's Avatar
I don't have a cel fix. I was under the impression that it wasn't needed with the stage 2 map since it was suppose to remove that cel code P0420
Old Apr 28, 2005 | 10:25 PM
isr96's Avatar
bump, it's still throwing the cel after i reset the ecu. it comes on anywhere between driving from 5-100 miles
Old Apr 29, 2005 | 06:50 AM
Egan's Avatar
If you have no cats in the downpipe, then you are going to throw the 0420. The only way around it is to reflash it out or get one of the mechanical or electrical CEL fixes (also known as MIL eliminators). Basically, the O2 sensor in your downpipe (the one with the yellow insulation) is teling the ECU that something is wrong with your cat (probably that you don;t have one ).
Old Apr 29, 2005 | 07:52 AM
isr96's Avatar
My reflash was suppose to get rid of this. Does anyone have a cobb ap and have stage 2? Did you have this problem?
Old Apr 29, 2005 | 10:03 AM
Egan's Avatar
Sorry, I meant ECUTek reflash.
Old Apr 29, 2005 | 01:18 PM
isr96's Avatar
oh...but the ap is suppose to do the same as removing it. Any AP users running stage 2 have this problem at all?
Old Apr 29, 2005 | 01:25 PM
soggynoodles's Avatar
Have you tried contacting Cobb on the issue.
Maybe try checking their forums.
http://www.wrxforum.com/cgi-bin/ultimatebb.cgi
Old Apr 29, 2005 | 04:45 PM
isr96's Avatar
Yah trey said I was supposively using an out of date version so I guess I will try again
smokinthunder
Dec 31, 2003 09:24 PM
Imprezfan1
Apr 27, 2003 09:06 PM
islandx
Mar 11, 2003 01:42 AM
Osgood30
Dec 15, 2002 08:33 PM
MeaCulpa
Dec 15, 2002 06:19 PM
