Which BOV for '05 STi???
Old Aug 9, 2004 | 05:34 PM
You can also just remove the silencer in the fender and then you can hear the factory valve quite well.
Old Aug 9, 2004 | 05:52 PM
Because your MAF sensor has measured air that the ECU expects to go through the combustion process. When you vent it off, the engine runs extremely rich (which is very bad for your catalytic converter, and you can be denied warranty repairs if it fails) and this causes the hesitation. Also, venting the pressurized air causes the turbo to have to "start over" to pressurize the manifold. Recirculating that air helps that process to go faster. Those two things are why stock bypass valves are better.
Old Aug 9, 2004 | 06:18 PM
sebring vetran's Avatar
Car Info: '05 WRX STi
BAN,
what and where is the silencer in the fender? does this effect waranty?
Old Aug 9, 2004 | 06:32 PM
Originally Posted by sebring vetran
BAN,
Search for "silencer mod." It doesn't affect the warranty, just makes the engine a little louder. And no need for the bold, jsut use the quote function please. Thanks.
Old Aug 11, 2004 | 04:11 PM
CALgoob's Avatar
is it possible to get a blowoff valve and get the a/f ratio adjusted?
