APS has done it again 468 HP
Old Nov 29, 2003 | 07:33 AM
fledis's Avatar
Car Info: '02 Turbo IS300 660rwhp
If, in fact, APS has an engine dyno then that is great and their flywheel hp #'s will be accurate. The pic on their website shows an STi sitting on an awd chassis dyno. That's why I was inferring they used that to achieve their #'s and then used a "correction" factor to calculate flywheel hp. Also, if they use an engine dyno to achieve all their hp #'s, why have a chassis dyno at all since they're inherently inferior? Maybe they imported the USDM STi motor to tear it apart and find out what Subaru used to build the motor.....and give us nice pics of the coated cast pistons
Next, what did they use to run the 1/4 mile time they quote? Did they do all the installs and tuning on the "spare" motor and then remove the motor from the STi and install the "spare" and run it? Did they use the "spare" motor to achieve the #'s and then install the same parts on the car and run the times? If so, how were they able to achieve the same tune on the car w/out the engine dyno? The chassis dyno will yield different numbers.
These are all questions I have, but don't necessarily need answers to. As I will be doing my own testing....using a chassis dyno and ultimately the 1/4 mile.
Scott
Old Nov 29, 2003 | 12:11 PM
fledis's Avatar
Originally posted by gohan
The question is both illogical and tautalogical.
Obviously they don't use an engine dyno to acheive all their hp #'s. And that is why they have a chassis dyno.
In order to use an engine dyno you need an engine - disconnected from the vehicle.
If you don't have a spare engine for every car you mod, you obviously need a chassis dyno.
They have both: THAT'S WHY THEY IMPORTED A COMPLETE ENGINE FOR TESTING, which would be useless without an engine dyno. I don't know why you find this is so hard to comprehend.
I know APS doesn't use an engine dyno for every car. The question, along w/ most I used in my response, was rhetorical. Just for the record. APS also imported an USDM Evo VIII, but doesn't mention importing a separate engine. Yet, they still have a dyno on the page showing flywheel hp. I guess they disconnected the engine from the vehicle to use the engine dyno
That is how they do that, right
Old Nov 29, 2003 | 12:46 PM
fledis's Avatar
Uhm....
"APS has fully imported a US specification STI" http://www.aps-wrx.com/us_spec/subaru/sti/2004_sti.htm
The significance of the 1/4 mile time of 11.9@118 is that it cross verifies that they have over 400 bhp, as there is no way you are going to achieve 11's with less than that.
So let me ask you. What exactly are you questioning? The horsepower? Good luck getting an STI in to the 11's@118 with less than 400 hp.
Can you tell me what wheel horsepower level will get you into the 11's? No you can't. You can't even generalize or come close. Not without specifying the dyno, the tuner and the methodology as whp numbers are 2nd hand and vary RADICALLY from dyno to dyno, car to car, and tuner to tuner.
The 1/4 mile time is very significant for me because that shows me the power the car is making. I'm not questioning how much power the car is making. My point was that I'd like to see whp #'s because the majority of us do not have access to engine dyno's and if we do, we don't feel like pulling our motors. If I were building a new motor I'd have no problem using an engine dyno before installing the motor, at the very least, to make sure everything is in good order. Flywheel hp #'s are hard for me to compare my car to because I will probably never use an engine dyno, but I guess I can always compare 1/4 times.
BTW, I think I can tell you what whp level will get you into the 11's. 500whp should do it no prob 450whp should also do it and probably even 400whp, but that's generalizing
The variance btw car to car, dyno to dyno, day to day, etc. will always exist. Can't do anything about that. I guess coming from the Supra world, where rwhp is always used, I'm a little biased toward whp.
Old Dec 20, 2003 | 01:02 PM
insaneSTi's Avatar
Car Info: Blue STi +Red del Sol VTEC
Did you notice they said the US STi's pistons are cast. They actually showed them too. I'm ****ing pissed the book from subaru plainly says forged molybdenum coated pistons. If this is found out to be true i think something should be done as that is false advertisement and we should get a petition going.
Old Dec 20, 2003 | 07:51 PM
SlickmisterN's Avatar
Car Info: 2004 Black/Gold STi
If this is the case ^ we should get a petition going. I can't believe Subaru would lie to us.
