Air Splitter help
Old Apr 25, 2006 | 04:10 PM
ThisizBrian's Avatar
Car Info: OCD Brian
Question Air Splitter help
Hey all,
I currently have a TXS TMIC on the 02 wrx. i have a JDM sti hoodscoop and i just need to know if a 04 usdm sti splitter will work on my jdm hoodscoop aplication. my mechanic matched up my stock splitter with the 04 sti and said the bolt patter matches but the only thing is the usdm hoodscoop might be different than the JDM one i have.
I read that APS had an aftermarket splitter that fitted the big TMIC's. Ive done a lot of searches and couldnt find anywhere to buy the APS splitter. so far i learned they arent made anymore, anyone know of any other options i can try?
thanks
Old Apr 25, 2006 | 04:26 PM
subie OCD's Avatar
Car Info: 04 STi
Whoa, small world, I just installed my TXS TMIC on Saturday. Like you I searched for over a week and found no 100% sure answer. Supposedly the MRT splitter works, but I couldnt find one. The biggest consensus is to modify the stock or STi spliiter or use no splitter.
I also have the jdm STi hood scoop, and I just removed the splitter all together...Im not really sure you need it on there, as the intercooler sits very close to the scoop. One unscientific test I did was after plenty of really hard driving (high boost, redlining), I parked it and put my hand on the ic and it was COLD! Not warm, not kinda cool, but COLD... actually yesterday at the concord meet an i-clubber said it was cold like a beer, lol.
Maybe one day when I have time I will modify the stock splitter to make a good seal with the ic, there are lots of tutorials/write ups of custom splitters/shrouds/seals on nasioc and clubwrx. Im sure a seal is better than no seal...but HOW MUCH better? Also, without a seal, it looks like more engine heat can escape throught the scoop...
Oh, btw, if you do find one that fits, let me know!
-Matt
Old Apr 25, 2006 | 04:47 PM
Car Info: OCD Brian
im going to try usdm 04 sti splitter.
i heard using some garage door weather stripping works. gonna try that when i get a chance. ill let you know how it goes.
Old Apr 25, 2006 | 04:57 PM
Car Info: OCD Brian
talked to a guy and he said 02-05 sti splitters will fit. well see in a few days.
Old Apr 25, 2006 | 05:01 PM
subie OCD's Avatar
Car Info: 04 STi
If you use an STI splitter, you will have to modify it, the TurboXS is a moster, much bigger than the Sti one! Good luck.
Old Apr 25, 2006 | 05:07 PM
Car Info: OCD Brian
modify the rubber piece or the actual splitter itself? i was planning on modifying the rubber piece.
Old Apr 25, 2006 | 05:34 PM
Car Info: OCD Brian
i found a gtspec splitter. this will work i assume.
http://forums.nasioc.com/forums/show...96&postcount=5
Old Apr 26, 2006 | 11:47 AM
subie OCD's Avatar
Car Info: 04 STi
Be sure to post the results if it works or not.
Old Apr 26, 2006 | 04:50 PM
Car Info: OCD Brian
i ordered the same day, should be here this week. got my 02 jdm sti hoodscoop from subydude.com. came painted for 205.
Old May 1, 2006 | 10:42 AM
jibby's Avatar
Car Info: 03 WRX Wagon
Scoop/air splitter question
Does anyone know if an STI scoop and splitter off an 06 will fit a 2003 WRX wagon?
Old May 1, 2006 | 10:56 AM
Car Info: OCD Brian
wont fit
bl0wnb0xerbabiE
Wanted
Feb 17, 2008 10:30 PM
strider327
Jul 20, 2007 02:12 AM
RavSpec
Vendor Group Buys/Specials
Dec 15, 2004 12:28 PM
kenchan
Jan 9, 2003 05:26 PM
