aftermartket DP with stock catback
Old Oct 19, 2006 | 09:50 AM
wimprezax06's Avatar
Car Info: WRX --> RX-8--〉E93
will the helix DP fit with the stock catback?
Old Oct 19, 2006 | 07:36 PM
lburrrna's Avatar
not really..you might have to use a different bolts. how thick are the flange of helix dp anyway? if they are..yup gonna have to use a a longer bolts
Old Oct 19, 2006 | 07:42 PM
strider327's Avatar
Car Info: 2005 WRX
It should mate up. Just have GB performance do it in Hayward. They'll make it fit for sure if anything. Talk to Gino.
Old Oct 19, 2006 | 08:29 PM
Superglue WRX's Avatar
I don't believe that DP uses the stock "donut" gasket, so I'm going to vote no.
Old Oct 20, 2006 | 07:39 AM
Drag-On's Avatar
Car Info: 06 Aspen White STI
No it will not fit perfectly.
Old Oct 31, 2006 | 10:48 PM
SuperHawk's Avatar
Car Info: 2006 WRB Wagon Ltd.
Get a Turbo XS stealth back!!
Super
Old Oct 31, 2006 | 10:52 PM
VRT MBasile's Avatar
It will fit. I know because I had it on my car. However, the helix's tend to have leaks at the DP/CBE no matter what
Old Nov 1, 2006 | 12:53 AM
willl's Avatar
Car Info: 04 STi - Aspen White
my titek dp bolted directly to my stock exhaust.
Old Nov 1, 2006 | 09:43 AM
RBMike's Avatar
I have the Helix catted DP & the stock cat back. I installed it and fits perfectly with no leaks. You use the gaskets & bolts supplied with the DP. No problems in 10K miles since I installed it. If it leaks, you did something wrong.
Old Nov 3, 2006 | 12:11 AM
willl's Avatar
be careful before you decide to install the downpipe. you might get boost creep, and if that happens your screwed. I was fortunate to have an accessport with my titek downpipe and sure enough my car boost creeped, then loaded stage2 map and it runs awesome now.
Old Nov 3, 2006 | 09:55 AM
i have TBE right now, the helix catless DP, and carbonti, and yesterday on the freeway i floor it, and my car went like POOM POOM, and my check engine light came on. =\ is that a boost creep? last time i had that, but the next morning the check engine light went back off, but this morning the light is still on =\
Old Nov 3, 2006 | 03:55 PM
willl's Avatar
it felt like you hit fuel cut off right?? and the car kinda kicked hard.
thats boost creep. time to spend $700 for a accessport lol.
its really worth it !~
Old Nov 16, 2006 | 01:32 AM
06grayrex's Avatar
Car Info: 06 WRX TR Cobb stage 1, Perrin crank pulley, SPT intake w/shield, grounding mod, fog light mod
Super
Will the Turbo XS 4" DP hit the a/c drain tube? Did you reuse the heatsheild? Did it bolt right up to the stock muffler? Is there any way you could post some pics? All or any more info would be awesome..Thanks
Old Nov 16, 2006 | 08:30 AM
STiYLIN's Avatar
it fits, I ran it for over 6 months with no leaks.
JourdanWithaU
Dec 6, 2012 06:35 AM
brucelee
Mar 7, 2009 04:43 PM
cleofis
Jun 30, 2007 04:39 PM
strider327
Jun 25, 2007 03:53 PM
