Helix DP with Stock Exhaust?
Old Nov 13, 2006 | 12:15 AM
Deserted1's Avatar
Car Info: 06 STi
Hey 06 sti here, I know the DP is 3" but ive seen ppl say it will work with the stock exhaust, is it true? I am guessing it will bolt up just need some gasket maker to seal the deal?
Any advise?
Thanks guys.
Old Nov 13, 2006 | 11:28 AM
RBMike's Avatar
I have an 05. I put in the Helix DP w/cat. It fits fine. You re-use the stock bolts on the turbo end and Helix provided a gasket & bolts for the "catback" end. No mods or extra parts needed. Your factory heat sheild will have to be cut if you want to use it, I just bolted on the Cobb sheild. Get a can of "PB blaster" from any local auto store & spray it on all the nuts/bolts the day before you want to do the install. This will make sure those pesky (rusty) turbo bolts come free without striping.
Old Nov 13, 2006 | 10:49 PM
Deserted1's Avatar
Car Info: 06 STi
thanks mike, so it will work thats good news, for now im just going to cut the stock heat shield a bit, then either build my own or buy the cobb. so to the stock exhuast I dont need to use any gasket maker? I read a few others that said it was needed to seal the deal for leaks. just checking so i have everything in order when i goto pull the car apart.
Old Nov 14, 2006 | 07:43 AM
RBMike's Avatar
I did not have any leaks. I did my install almost a year ago. I used no extra gasket. The biggest issue for the install was getting those turbo bolts out but if you use the PB blaster they come off like they were loose.
Old Nov 15, 2006 | 07:51 PM
impreza-tux-121's Avatar
Car Info: 2006 Impreza WRX Sti/Hawkeye
Any advise?
Thanks guys.
same here i'd like to know
Old Nov 15, 2006 | 09:29 PM
WRX>Civic's Avatar
Car Info: '03 PSM Wingless WRX
the bolts are easy to get to as long as you have a good wrench or socket that can be extended... It would make life easier if you ask a friend for some help xD
Old Nov 15, 2006 | 10:00 PM
Deserted1's Avatar
Car Info: 06 STi
well i plan on doing mine at a toyota dealership on a rack, with a friend so im covered in that respect. LOL
Old Nov 15, 2006 | 10:03 PM
VRT MBasile's Avatar
yeah, the bolts for the dp to cbe connection are a complete *****! I dont understand why there are such stiff springs on them
Old Nov 16, 2006 | 11:03 AM
Renick Motorsports's Avatar
Car Info: 2006 wrx, sr20DET Datsun 510, 2004 Sti, 2001 GC8
yes it will work, i had my car like this for a while and its really didnt make any diffeerence in the loudness of the car.....but to seal it go to a subaru dealer and get some stuff we call fuji bond, the part # is 004403007, the stuf works everywhere that something need to be sealed and it the best liquid gasket i have evr used and all the techs agree with me, the stuff is just awsome its $26.28
gruppe-s
Engine and Drivetrain
Aug 11, 2006 05:34 PM
gruppe-s
Aug 1, 2006 05:14 PM
gruppe-s
Mar 10, 2005 12:37 PM
