2006 wrx getting into gear
Old Sep 14, 2012 | 11:43 PM
Lookinforwrx's Avatar
Car Info: 2006 wrx
Sometimes when i try to get into first gear or reverse it doesnt want to get in gear. What could be the problem? Sometimes when i reverse it takes about 3 tries to finally get into gear. Could it be my gear oil? Also when i am reversing my car makes a clunking noise?
Sent from my iPhone using i-Club
Old Sep 14, 2012 | 11:51 PM
Javirex23's Avatar
Car Info: 07lmtd 6spd wrx eq tuned
Sounds about right.... Mine did the same 1st gear from a stop it's cool all good and normal, once your rolling forget about it. And as far as reverse, try double pumping the clutch or put it in first gear before into Reverse
Old Sep 15, 2012 | 06:45 AM
bushido11's Avatar
Blip throttle with clutch out , with rpm up push clutch and into 1st. Viola! Double clutch. Easy. Change tranny fluid and you may need a clutch
anthonys192
Jan 20, 2014 03:41 PM
anthonys192
Nov 21, 2013 10:10 AM
anthonys192
Nov 20, 2013 10:45 PM
Subadubaru
Aug 26, 2009 03:53 PM
neillmatic
Aug 21, 2005 09:29 AM
