2005 sti what should i do next?
Old Sep 8, 2005 | 12:32 PM
Juelz5420's Avatar
Car Info: 2010 Subaru Sti
thanks dep i am biulding my car so i will just get the uppipe and you suggest the pde where can i go on the web to look at it. and what injectors do you suggest i am looking to be around 400hp everyday driver.
Old Sep 8, 2005 | 04:44 PM
depdivr's Avatar
Car Info: 2005 Black WRX STI
Originally Posted by gilmore25
I say get a DB 20G, Walbo fuel pump, PE850 injectors and a Custom tune then call it a day with a nice streetable setup
http://www.fastwrx.com/pdeflexuppipe.html
Here is a link to a site that sells the PDE flex up pipe. I'm not saying you should buy it from them but at least you can look at a blow up photo to get an idea of workmanship.
Gilmore is right on with his recommendation for the Walbro 255 L/hr fuel pump. I prefer Perrin injectors but Power Enterprises (PE) is solid as well. His recommendation of 860 cc injectors is right on for a 400+ whp car. Remember that injectors are rated for a certain flow rate, at a certain fuel pressure. For instance, at lower fuel pressures, the injector will be rated to a lower flow rate.
I like Perrin because they are modified Subaru STI injectors, they are modified and Guaranteed to work. They are plug and play - all you have to do is tell the computer what flow rate they are running at.
http://www.perrinperformance.com/Pro.../Injectors.htm
400 whp is a serious street car - my STI is running at 340 to 350 depending on the tune (on 92 octane pump). I can get up to 400 with race gas and a more aggressive tune.
Old Sep 8, 2005 | 04:56 PM
depdivr's Avatar
oh here is a cool thread on the DB 20G...
http://forums.nasioc.com/forums/show...6#post10949096
I would recomend Forced Performance turbos. They have been R&Ded for Subaru STIs. I went with the Red. Slightly more capcacity than the FP Green (a very popular choice) with a slightly slower spool up. Overall you get a very solid and smooth powerband all the way to redline.
http://linux.forcedperformance.net/m...egory_Code=WRX
This next link is cool...
The is Jeff Perrin's STI (The owner of Perrin Performance)... It is running with a FP Green turbo and with race gas is over 400 whp.
http://www.pdxtuning.com/featured_cars/jeffp.htm
Again, hope this helps
Juelz5420
Sep 4, 2005 05:22 PM
cohlineman
Nov 16, 2003 12:22 PM
Sevielle
Jun 4, 2003 07:20 AM
NRTmotorsports
Jun 4, 2003 02:26 AM
Kevin02REX
Apr 19, 2003 01:42 PM
