06 sti blown engine
Old Feb 9, 2007 | 03:36 AM
thunder_sti's Avatar
Troll
Engine seized...Did you ever changed your oil
Old Feb 9, 2007 | 05:33 AM
SineSTI's Avatar
Car Info: MY06 STI
Sorry for that, but did you remaped car? This is a "must" if you change exhaust components. Motors blew'n on several test cars in Italy just for this reason, because they want some sound (without remap).
Old Feb 9, 2007 | 11:39 AM
Armani_sti's Avatar
Car Info: y
yea i changed the oil every 2,500 miles. oil was only 4 days old
Old Feb 9, 2007 | 11:40 AM
Armani_sti's Avatar
Car Info: y
Engine seized...Did you ever changed your oil[QUOTE]
no i did not have a remap @ time!
Old Feb 9, 2007 | 11:46 AM
SubyN00by's Avatar
wow, sounds like a 1 in a million case, spinning a bearing at 29k with that little mod...
Old Feb 9, 2007 | 11:51 AM
VRT Gump's Avatar
sounds like you dropped the clutch the wrong way at the track and blew out the mounts, and as far as the exhaust with no mapping, very bad. Did you ever throw a Check Engine light for overboosting? If you kept going WOT and overboosting you could have damaged the internals due to the fuel cut going on so many times.
Old Feb 9, 2007 | 12:03 PM
Armani_sti's Avatar
Car Info: y
tell me about it dealer will not warranty so just waiting for pay check to buy engine lift to start pulling the motor so i can bring it to gruppe-s
Old Feb 9, 2007 | 12:06 PM
Armani_sti's Avatar
Car Info: y
by any chance do you know where i can get a good maintance manual for the 06 sti or a dealer cd so i dont **** up taking it apart and reasemble the short block
Old Feb 9, 2007 | 12:10 PM
Armani_sti's Avatar
Car Info: y
[QUOTE]
sounds like you dropped the clutch the wrong way at the track and blew out the mounts, and as far as the exhaust with no mapping, very bad. Did you ever throw a Check Engine light for overboosting? If you kept going WOT and overboosting you could have damaged the internals due to the fuel cut going on so many times.[/QUOte
I was not throwing a check engine light but. i had enstalled mechanical cel fix from gruppe-s
was planning to get a remap
did not know i was overboosting!
Old Feb 9, 2007 | 12:29 PM
SubyN00by's Avatar
[QUOTE=Armani_sti]
don't go to gruppe-s.
Check with GSTMotorsports, talk to Mike and he'll help you out.
You can PM them on here or check their website www.gstmotorsports.com
(btw, Mike is who made the Gruppe-S reputation...until they ****ed it all up)
Old Feb 9, 2007 | 12:31 PM
VRT Gump's Avatar
[QUOTE=Armani_sti]
it might not have brought the CEL up, but I know a turbo back will lower the compression in the exhaust which will mess up the wastegate cycle and cause the turbo to spool up way to high for what the computer wants it to. Go with that Subyn00by said and check with Mike at GST. If he cant fix it, but a new car.
Old Feb 9, 2007 | 04:01 PM
Armani_sti's Avatar
Car Info: y
SubyN00by
06WRX4ME
i'll check that i probably give a call today or tommorow thanks for the 411 i didnt know mike does not work at gruppe-s anymore!!!
Old Feb 10, 2007 | 12:06 PM
Armani_sti's Avatar
Car Info: y
bump
Old Feb 10, 2007 | 01:35 PM
SubyN00by's Avatar
Originally Posted by Armani_sti
bump
any luck with GSTMotorsports?
Old Feb 11, 2007 | 02:15 AM
Armani_sti's Avatar
Car Info: y
Exclamation
yea, mike did e-mail me back was wondering if i was going to reuse the existing block and would save me $1,200 dollars or get oem brand new block for $2,800. but i pretty much put i was being offered from gruppe-s but dont know if he is trying to figure out if he can match gruppe-s on built short block and extra parts as for turbo upgrade and cobb ap2.0??
