04 & 05 uppipe
Old Mar 14, 2005 | 09:49 AM
laoba's Avatar
Car Info: rx8
04 & 05 uppipe
are the 04 and 05 uppipes exactly the same on the sti?
Old Mar 14, 2005 | 09:57 AM
soggynoodles's Avatar
The up pipes for a WRX have a cat. The up pipes on the STI don't.
Old Mar 14, 2005 | 10:07 AM
laoba's Avatar
Car Info: rx8
thanks, but is the uppipe any different from the 04 and 05 sti? i'm looking to put a 04 sti up into my 05 wrx...this should fit minus the egt sensor? this is not an o2 sensor right?
Old Mar 14, 2005 | 10:27 AM
the upipe for the 04-05 are the same.
It should fit without a problem.
It's an o2 sensor(i think). You need to do the CEL fix or you'll get a CEL.
Old Mar 14, 2005 | 12:24 PM
Egan's Avatar
The O2 sensor is in the "header". The EGT sensor on the WRX is in the uppipe. You'll need the EGT cel fix which is $.99 worth of resistor from Radio Shack.
Old Mar 14, 2005 | 12:29 PM
Egan's Avatar
The resistor you need is 2.2Kohm and 1/2watt. You can remove the EGT probe altogether and disconnect it at the harness. Then plug the resistor into the remaining harness half and tape it up.
Old Mar 21, 2005 | 11:57 AM
laoba's Avatar
Car Info: rx8
Thanks , are there any negative effects (other than to check the uppipe cat) of removing the EGT sensor? does the ECU use this for timing/fueling anything like that?
Old Mar 21, 2005 | 12:17 PM
Egan's Avatar
Nope. The ECU uses it to make sure the uppipe cat is working correctly. As long as you use the resistor mod, you won't get any CEL's.
Your car is actually much safer without the EGT probe in there. If that thing ever fails, it's going right into the turbo blades.
VitaminWRX
Sep 8, 2006 09:03 AM
downshift
Feb 16, 2004 12:41 AM
downshift
Feb 10, 2004 03:19 PM
huck
Dec 2, 2003 10:53 PM
V8haha
Jun 26, 2003 12:53 PM
