Zero boost pressure
Old Jan 14, 2006 | 01:38 PM
atreger's Avatar
Car Info: 02 WRX, BLACK
Zero boost pressure
In an instant I went from 18 psi on my vf-39 to 0. As soon as the boost tries to go over 0 psi it makes an odd fluttering noise. I checked all the hoses and checked for leaks and can't find any. I don't have any CELs. My car is an 02 wrx with vf39 with all supporting mods. 90,000 miles on the car and about 25,000 on the vf-39. I have been told the wastegate on my turbo doesn't work right. Could it need a new wastegate? or is the turbo shot? Please help!
Old Jan 14, 2006 | 07:10 PM
atreger's Avatar
Bump for undrivable car
Old Jan 14, 2006 | 07:11 PM
Me&05WRX's Avatar
Car Info: 2015 STI
Check your wastegate arm actuator. The c-clip that's holding it may have fallen off.
Old Jan 14, 2006 | 07:54 PM
atreger's Avatar
will do, thx.
Old Jan 14, 2006 | 08:50 PM
VIBEELEVEN's Avatar
Car Info: 03 WRX
I bet you almost anything that's what it is.
Old Jan 15, 2006 | 11:34 AM
atreger's Avatar
:-( the C clip is still on there. I can manually pull open the wastegate from the arm and it seems to have normal tension. Anything else it could be?
Old Jan 16, 2006 | 01:52 AM
Me&05WRX's Avatar
Car Info: 2015 STI
Sorry man... I don't really know what's next to check since you've done check up on the hoses. Best thing to do is have a mechanic check it.
Old Jan 16, 2006 | 09:58 AM
PSI-PWR's Avatar
Car Info: 04STi AMS Tuned
just installed a brand spanking new vf34 (ported), helix 660cc injectors and warlboro 255lph fuel pump into my 04 and im coming across the same problem...almost. when i get on the gas, it hits .04 bar (roughly about 8psi) then it goes flat w/ some sort of fluttering sound as well. but this is with my utec running passive (map 0) on a stock ecu. all supporting mods such as up/downpipe, blitz stainless SUS intake, hks carbon-ti exhaust and TXS tuner lite are on there, but i have a cel. the car drives fine but i think it's because there is no engine managment running and the stock ecu is confused as to what's going on.
Old Jan 18, 2006 | 04:37 PM
atreger's Avatar
OK I figured it out once I took out the turbo. 2 of the fins on the turbine are totally shattered...YUP, and the whole backside of the turbo is caked in oil. So I put back in my td04 . Anyone know if the vf-39 turbine is replacable?
suby_dude
Feb 12, 2008 01:28 PM
DanZ
Wanted
Mar 20, 2004 12:24 AM
02wrbluewrx
Sep 25, 2003 11:00 AM
Wrxplaya11
Aug 16, 2003 10:40 PM
turbo_j
Mar 16, 2003 02:49 PM
