wut kinda MBC
Old May 21, 2005 | 11:43 PM
norcalridin's Avatar
Car Info: 2002 WRB WRX
wut kinda MBC
what kind of manual boost controller is the best and cheapest.. i guess just best bang for the buck... right now i have uppipe, and turbo back.. with a drop in filter.. and i was wondering if i should invest in a mbc and just put the boost up to 15-16psi... only for times when i go to the track and when i feel like goofy around!! .... eventually im going to upgrading the turbo with injectors, and a new top mount.. but anyways just wondering whut the best mbc is.. and maybe if there is a conflict going on about having one...
Old May 22, 2005 | 11:24 AM
topcover's Avatar
Car Info: '02 EJ25FXT Stage 2 "No Laggin' Wagon"
Rather than screwing with a MBC, I would recommend going to a local tuner to have your ECU tapped and tuned to maximize the mods you have currently installed. Well worth the investment, IMO.
Old May 27, 2005 | 02:13 PM
GasPipe DreameR's Avatar
Car Info: lowered blk04 with no motor
turboxs works cool
Old May 27, 2005 | 05:58 PM
duo's Avatar
duo
Car Info: WRB WRX 2004
mbc=death to car without em
Old May 31, 2005 | 08:16 PM
are you sayin that the car will die if you dont have one.. or the car will die with one...
Old Jun 1, 2005 | 07:44 AM
VRWRX's Avatar
Car Info: 2005 CGM WRX Wagon
mbc=death to car without engine management
Old Jun 1, 2005 | 04:44 PM
oh ok now i get it... thanx..
Old Jun 8, 2005 | 12:27 AM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
do a search on open loop vs. closed loop fueling and MBC's. You should come up with plenty of info about the issues associated with running an MBC with the stock ECU.
Old Jun 10, 2005 | 07:20 AM
ride5000's Avatar
what year is your car?
edit: profile says 02.
due to the older ecu revision, you can run an MBC. to run safer by sidestepping the part throttle full boost issue, buy one of ed/eq tuning's open loop managers.
stupidchicken03
May 28, 2014 08:36 PM
FuturistiK_STI
Jun 30, 2011 08:45 AM
LookingForPower
Aug 20, 2005 12:16 PM
Wrxplaya11
Jul 20, 2004 07:21 PM
