WRX Smog Check help
Old Aug 21, 2004 | 07:19 PM
RoadSpike's Avatar
Originally Posted by deeman81
I have a WRX with a vf30 ,sti injectors, and a utec. I put the stock turboback on, is it possible to pass smog as it sits now?no cat in the uppipe? I also have a cel fix kit on the o2 sensor. ANy help would be great.
Thank you
Dee
The two in the downpipe should clean it up enough to pass emmissions unless your in california and they spot your aftermarket turbo then they could very well bust you over that... or anything
Old Aug 23, 2004 | 04:12 PM
Jimbo's Avatar
Smog refs are not going to recognize an aftermarket turbo. Most of these guys are not the sharpest knife in the drawer if you know what I mean.
They're going to look for anything obvious (i.e. exhaust and intake mods) that would affect emissions. They will notice if you do not have the stock midpipe with cat and they might notice the downpipe, but no way would they be able to see an aftermarket uppipe. If you are paranoid, put the stock TBE back on before the test. The only concern is that you will be running pig rich and there may be some timing advance with the UTEC map which may cause some concerns. Anyone else care to comment?
I would love for Cobb to come out with a Smog flash that would basically allow for passing CA emissions by putting the stock TBE on with no other changes.
Jimbo
DabiDa
Aug 16, 2013 11:43 AM
wrx 03i
Aug 18, 2011 06:58 PM
AWDnutjob
32
Jul 6, 2008 06:06 PM
