wrx running lean...
Old Apr 28, 2007 | 11:54 PM
MO REX's Avatar
Car Info: 02 PSM WRX
I'm almost positive the dealer or any tuner can. I know there were detonation issues with some of the earlier US WRX's and the dealers were reflashing the ecu's to fix the problem. Call a local dealer, tell them the problem and see if they can reflash it back to the OE map.
Check this out http://forums.nasioc.com/forums/showthread.php?t=671294
Old Apr 30, 2007 | 07:45 PM
k3k0a's Avatar
Car Info: 2014 Mitsubishi EVO MR/2014 Wrx
ok car runs a lot better after the fuel filter.... but it still happens only at wot, and MO REX if u remember i had the boost problem i got the new solenoid from the dealer and it still does the same thing ive replaced all the hoses with new stock ones and everything could the boost problem be with the ecu? cuz i know the cobb ap controls that solenoid... i called the dealer and they said they can re-flash my ecu... it cost about a 100bux should i just do it to do it?
Old Apr 30, 2007 | 08:48 PM
MO REX's Avatar
I just scanned our discussion on the spike issue and yes I do remember. Sorry to see the problem hasn't gone away. Did you buy the car from a Subaru dealer? If you did (I think you did) tell them in a nice way that they need to reflash it for free or at least figure out what's going on since they sold you a defective car. Are you positive the original owner put the OE injectors back in?
It's not easy to diagnose a problem over the Internet and I'd hate to tell you to spend $100 without knowing it will work. That's why I usually look for cheap ways to figure these things out.
If it was my car and the dealer wouldn't help me out I'd make 100% sure the injectors were not aftermarket or modded OE injectors. When I knew I had the OE injectors I would go out and buy an AP. If the AP wouldn't install because another AP was already married to the ecu I'd take it from there. This is just what I'd do since I would eventually buy an AP anyway.
If you're trying to troubleshoot it on your own you have to risk spending $ on things that might not work. I have to work and go to school at night tomorrow but I'll try to give my mechanic a call and see what he thinks would be the best way to figure this out.
I'll definitely get back to you within the next 2 days and I'll try my best to do it tomorrow.
Old Apr 30, 2007 | 08:56 PM
MO REX's Avatar
One more thing.
I really think you're experiencing the OL/CL transition problem discussed in the last link I provided and the AP would take care of it but since there are so many unknowns it's kind of hard to know for sure.
Old May 1, 2007 | 08:26 PM
MO REX's Avatar
I was thinking about it today and you ended up making your own MBC for a temporary boost spike fix. Are you running the new OE FBC or the home made MBC?
Old May 1, 2007 | 10:49 PM
k3k0a's Avatar
i ended up just using the homemade mbc but im only running 9psi... when i go to work i have to climb a hill and the stock fbc is so messed up that it would overboost just trying to get up and i would have to go really slow so i just ran the mbc
nu02wrx
Aug 6, 2003 01:16 AM
adria
Jun 1, 2003 09:25 AM
wonton2049
May 4, 2003 06:29 AM
Bean
Jan 22, 2003 01:44 PM
SmuttyStyles
Jan 1, 2003 06:43 PM
