WRX Header
Old Sep 18, 2004 | 08:20 AM
t-wrexxx's Avatar
WRX Header
Can anyone point me to a good how-to for a wrx header install??
Can this be done in my garage without a lift?
Old Sep 18, 2004 | 10:00 AM
awns729's Avatar
Car Info: want a WRX
Maybe theres one on www.scoobymods.com
Old Sep 18, 2004 | 10:14 AM
amelnikov's Avatar
Car Info: 2002 WRX Sportwagon 292WHP
As long as you got a set or ramps, it's very easy. Should take about an hour if you take your time. Just make sure to note how all the bolts got and which way the gaskets are pointed. You may also want to spray the heat shield bolts with some penetrating fluid prior to starting the work and make sure you wear some eye protection while under there. Air tools make the whole job much easier.
Alex...
Old Sep 18, 2004 | 06:10 PM
awns729's Avatar
Is it hard to do for someone who hasn't had much experience with cars? Do you need to remove any parts to remove the header?
Old Sep 19, 2004 | 04:36 PM
Long_Travel_WRX's Avatar
Car Info: stock 04 wrx sedan
u have to remove to 02 sensor and unbolt the up pipe where it bolts to the header other than that take the heat shields off both side and 3 bolts perside pretty easy took me about 40 mins after a beer or two
Old Sep 21, 2004 | 04:15 PM
supra_man's Avatar
but drink the beer after you install not before if you do then you will end up installing the headers on your roof or something.hahaha
NorCalDC5
Jul 18, 2007 12:15 AM
unstble
17
Dec 9, 2005 02:27 PM
minisiu
Oct 22, 2004 03:26 PM
mj
Dec 10, 2003 10:21 AM
