what sort of gains from header? (was: Header question)
Old Dec 6, 2005 | 10:49 PM
unstble's Avatar
Car Info: WREX
Header question
Actually, what I would like to know, is whether you are really getting good gains from purchasing headers, or is it the up-pipe portion that really helps with the performance gains?
Old Dec 6, 2005 | 10:55 PM
WrbImprezaSti's Avatar
Car Info: WRX
the headers will give you alot of gain. my friends car use to be neck and neck with me, both Sti's. Then he got the manifold and pulled away by like almost 2 cars with the manifold.
Old Dec 6, 2005 | 11:21 PM
Krinkov's Avatar
heres a dyno graph back from my STI, only part changed was added wrapped GT-spec headers. +2.3whp and 21.5wtq just with the headers. as you can see from the circle thats the only amount of lag thats present, you dont even notice it unless you see it on the chart. Though when I put headers on my 02 wagon the lag was very noticable and took them back off. Is yours an STI?
Old Dec 7, 2005 | 08:57 AM
unstble's Avatar
Car Info: WREX
No, mine is only an '05 WRX sedan. So, putting headers on a wrx, one would need to get tuning for it to run properly, right?
Old Dec 7, 2005 | 09:28 AM
mattsn0w's Avatar
yep, and most likely you'll only notice mid/high end gains though.
Old Dec 7, 2005 | 11:49 AM
unstble's Avatar
Car Info: WREX
thanks for the info.
What type of gains could be received with headers, in addition to an up-pipe and cat-back exhaust?
Old Dec 7, 2005 | 11:53 AM
Car Info: WRX
the wrx has a cat on the up pipe, so if you get an aftermarket up pipe gains will be good.
Old Dec 7, 2005 | 04:10 PM
unstble's Avatar
Car Info: WREX
I already have an up/down/cat-back = Up-pipe w/Turbo-back. I am just trying to find out what/if headers would give me any gains, or if the gains were actually only really felt due to changing out the stock up to an aftermarket up-pipe.
Old Dec 7, 2005 | 04:15 PM
mattsn0w's Avatar
The 2 biggest gains you can get are Upipe, and Engine Management.
Adding a short DP/full DP will be the next step.
I personally am looking for better low end torque, my top end is fine.
This is why I will not upgrade to a bigger turbo, unless it spools up faster.
Currently I am looking at a VF23 to see what results people are getting with that but have not found any solid information yet.
Old Dec 7, 2005 | 04:47 PM
Krinkov's Avatar
what he said.
save your money on headers if you already have an up-pipe, the lag is way more noticeable on a 2 liter than on the 2.5, and the top end on the 2 liter is so much nicer than it is on my 2.5 I never really feel a need to rev any higher, keep all the low end and spool you can!
Old Dec 7, 2005 | 09:20 PM
unstble's Avatar
Car Info: WREX
cool! Thanks for all the insight!
Old Dec 7, 2005 | 10:23 PM
slvrsubywgn's Avatar
Exactly what Krinkov and Mcdrama said. Low end is your friend. I don't want the crappy lag and fuel mileage that bigger turbos give you (unless I can find one that spools better and gives me alot better low end). Check out and see what Ed did with his almost stock WRX. This is who I am going to have tune my car.
https://www.i-club.com/forums/bay-area-15/finally-got-around-tuning-my-wagon-interesting-results-115774/
Old Dec 8, 2005 | 07:24 AM
unstble's Avatar
Car Info: WREX
Very interesting!
Old Dec 9, 2005 | 10:18 AM
WRX Rush's Avatar
Car Info: Stage 4+ Bugeye
I love the top end I gained from my headers on my 03 WRX. I don't even notice the "extended lag", when I got my car tuned, since I got my turbo ported and polished, my lag was down and the headers added a little bit of lag. I can barely notice the difference and the top end is righteously powerful.
Cheers,
Austin
Old Dec 9, 2005 | 11:22 AM
unstble's Avatar
Car Info: WREX
Most racing happens with the top-end anyways, right?
