wrapping catted downpip
Old Jan 14, 2006 | 04:06 PM
ryanjorunner's Avatar
wrapping catted downpipe
I just recenty bought a helix catted downpipe, and was considering wrapping it with some high temp header wrap. I was wondering if i should wrap the cat too. would holding the hot gasses in the cat cause it to burn up? should I even wrap any of the down pipe, for the same reason? Just wondering. I still need to pass emissions so a burnt up cat wont do me any good
Old Jan 15, 2006 | 01:36 AM
if the cat isnt carb legal it isnt legal
you dont need to keep the heat in after the turbo
Old Jan 15, 2006 | 09:22 AM
Can't people pass a sniffer test with a high flow though? I'm not worried about the visual, I've seen them do the inspection, they dont even pop the hood, or look under the car around here. what do you mean you dont need to keep the heat in after the turbo? wont keeping the exhaust air hot increase the air flow? isn't that why others wrapp thier downpipes? And why companies sell coated downpipes. I'm just wondering if keeping the hot air in the pipe is going to burn up the cat.
Old Jan 16, 2006 | 10:39 AM
do you have an up pipe cat?
Old Jan 16, 2006 | 11:36 AM
I'm putting an hks up pipe in whenever i install the downpipe.
Old Jan 16, 2006 | 11:58 AM
oh i was going to say you can probablly get away with catless down pipe but catted up
the pipe on teh down pipe is bigger than the up pipe so some velocity is lost there
up pipe is what you would want to do
Old Jan 19, 2006 | 07:45 AM
ride5000's Avatar
no, it will not.
a coated or wrapped DP will keep heat transmission from pipe to TMIC down to a minimum.
it will keep exhaust gas velocity high.
it will also help the cat do it's job more efficiently. they need heat to catalyze.
my bosal shorty has been wrapped for over 2 years. looks fine.
Kay95
Feb 22, 2004 11:39 AM
Salty
Aug 14, 2003 11:25 AM
Salty
Aug 13, 2003 11:11 PM
