Work the Heads
Old Oct 5, 2005 | 08:11 PM
Smooth_Ej20's Avatar
Car Info: 2004 Wrx
Question Work the Heads
In the not so distant future i plan on switching to a 2.5l block in my 04 wrx. I have searched and asked people i know but i keep getting mixed results, so ill ask you guys. Some people have told me to have the heads ported and polished and get new valves, springs, retainers etc. in order to keep the heads from floating and to increase the top end and redline. But i thought that the WRX heads flowed pretty well and i dont want to have a full top end wrx. I am interested in the higher redline. If you guys could weigh in i would greatly appreciate it. all the people i know have getten me pretty confused about the best way to go.
Old Oct 6, 2005 | 12:21 AM
jwrx's Avatar
Car Info: 04 WRX Sedan
a higher rev limit seems kinda pointless to me if your powerband isnt at the top of the rpm range...
Old Oct 6, 2005 | 04:20 PM
Vicore_Wrx's Avatar
Car Info: 2003 WRX, blue
Check out Axis Racing, Craford Performance, and cobb Tuning. they all offer what you want in the way of head work. For a stock 2.5 I wouldn't do any head work. If you go with a 2.5 with pistons, rod etc... I would look into it. do I search for the above shops they are all very good. As was already said I would raise the rev's for no reason. hehe
Old Oct 6, 2005 | 10:05 PM
mbquarts's Avatar
Car Info: 03 MBP WRX
AVCS...doooo iiiiittttt.
Old Oct 11, 2005 | 10:28 AM
dubRexer's Avatar
Car Info: white/gold sti
people say to use wrx heads, build the heads with a good valve train set up but honestly nothing really changes but you're redline and to second jwrx it's pointless to increase redline without having topend... kind of an oxymoron there. but avcs is the way to go.. you'll enjoy it much more unless you want to launch your car at 9k revs and have hella topend power...
Old Oct 11, 2005 | 10:35 AM
1reguL8NSTi's Avatar
Car Info: 05 STi
Yeah, avcs is the way to go. If you want top end performance flow becomes a big deal so port and polish while def. make a difference. As far as the dollar/hp ratio goes it's also going to cost you. I personally won't crack into the internals unless I was getting everything done (i.e. pistons, rods, valves, cams, etc...) but that's just me. It'll save you money in the long run and if your turbo accomodates with boost production you'll be able to crank it up a bit with the increased security. If you want to get better top end without the internal work get a bigger throttle body (or bore it), intake manifold and tumber deletes. Silicon hoses and Y will also give a little extra in that dept. Hope that helps a little.
Old Oct 12, 2005 | 08:26 AM
Car Info: 2004 Wrx
I figured as much about using the regular heads. I did think though that you had to have STI heads for the AVCS? I may be mistaken but, how do you go about getting the AVCS?
Old Oct 12, 2005 | 09:54 AM
mbquarts's Avatar
You can get a forester xt long block, and then have your ecu reflashed to utilize the AVCS. Check out gruppe-s they almost always have cheap motors for sale.
mystilexzero
Aug 27, 2009 01:28 PM
RavSpec
43
Jun 22, 2009 09:34 AM
WorldONE
Engine and Drivetrain
Apr 13, 2007 06:22 PM
EJ20Legacy
Nov 13, 2006 05:47 PM
gruppe-s
Jul 21, 2005 08:32 AM
