Will a new BOV mess up my tune?
Old May 28, 2006 | 07:52 PM
VRT MBasile's Avatar
I got my ar tuned with the stock BOV, butt he other day I was using the 100 octane map, and I noticed it sounded like the BPV was leaking a little bit when I went WOT. If I get an adjustable BOV (probably worx dual stage) will it mess up the tuning of the base map too? I'd be running it in recirc mode while on the 91 map and atmospheric for the 100 octane map during races. Would I be able to fix any problems with the tuning with the external spring adjustment? TIA guys
http://boostkits.com/worx_tuning_dual_stage_bov.html
Old May 29, 2006 | 11:03 AM
how much boost are you running and why would you go atmospheric when your on 100 octane?
Old May 30, 2006 | 03:27 AM
testes1010's Avatar
FYI, you can't hear a BPV leak...it leaks back into the inlet...
the way you know a BPV is leaking is when you raise boost during tuning & your MAF voltage does not go up...
Old May 30, 2006 | 10:03 PM
well when I went WOT the BPV sounded funky, not like it normally does. I was thinking of doing atmospheric while on 100 octane because I use ot for rally-x, and I figured the way the car handles with an atmospheric BOV (slows down a lot more when letting off the gas) would help me slow down for the tight turns
Old May 30, 2006 | 10:06 PM
testes1010's Avatar
a BOV or BPV has nothing to do with the slowing down of a vehicle....
Old May 30, 2006 | 10:18 PM
have you driven a car with an atmospheric? its amuch more sudden slowing down when it lets off. it doesnt seem to have any long term slowing down effect, just when you suddenly let off the throttle
atleast thats my experience
Old May 30, 2006 | 10:34 PM
testes1010's Avatar
yes, I had a TurboXS RFL for a couple months until the noise got too much for me....I reverted back to stock, then upgraded to an APS DualVent BPV when the crushed stocker was still blowing-by during tuning.
shaggadelic
Nov 3, 2012 01:39 PM
02whitebugeye
Jan 26, 2010 10:08 PM
HungrySTI4V8
14
Sep 27, 2008 02:14 PM
dustythedeal
Mar 12, 2008 01:02 AM
