White Smoke
Old Oct 4, 2006 | 04:49 PM
WRX-CBR's Avatar
Car Info: 03 WRX
White Smoke
For the last couple of months my car has been throwing white smoke from the exhaust. I'm trying to see if anyone can help me find the source of the problem.
The car warms up fine with no smoke at all. Once I get going it blows a bunch of white smoke for a couple of seconds then goes away. I only does it when the car has been sitting for a while (engine off). I checked the water reservoir and there are no signs of consumption or oil.
My current engine mods are cat back, up pipe, down pipe (just installed, it did it before too), and Accessport.
Any ideas what it might be?
Old Oct 4, 2006 | 07:32 PM
bring it to a meet so we can see
when the car has been sitting for a while and is cold
take teh cap off the radiator and see if oil is in it.
is there blow by
and im not going to guess turbo seals again
Old Oct 5, 2006 | 06:24 AM
axelthrasher's Avatar
Car Info: Subaru
I actually have a very similar problem - only mine is acompanied by a 3 cylder misfire. I haven't found anything yet. ;(
Old Oct 5, 2006 | 06:40 AM
HomerJay's Avatar
Car Info: MY00RS25
Bad head gasket. Check you coolant levels. Usually white smoke is from coolant.
Old Oct 5, 2006 | 08:55 AM
Car Info: Subaru
The only tricky thing about that, is that my coolent levels never change.
Old Oct 6, 2006 | 04:23 PM
WRX-CBR's Avatar
Car Info: 03 WRX
Now it throws white smoke when idling. Not in the morning (cold) though. Like if I'm at a drive through I start smoking like crazy.
Sigma, I do have blow by.
Old Oct 7, 2006 | 10:07 AM
WRX-CBR's Avatar
Car Info: 03 WRX
Old Oct 7, 2006 | 10:22 AM
i think its oil burning aka the blow by igniting
i am thinking its just because you dotn have cats
Old Oct 7, 2006 | 10:33 AM
WRX-CBR's Avatar
Car Info: 03 WRX
I guess I'll install a catch can (doesn't hurt). And it did it even though I had a cat in there.
Old Oct 7, 2006 | 10:40 AM
Ichinobu's Avatar
If it is white and has a sweet smell it is coolant.
oil will have a burning smell to it.
Like the other guy said . head gasket.
hold a rag behind the exhaust so the exhaust will blow on it.
check the rag for coolant/water or oil.
the janitor
Old Oct 7, 2006 | 10:41 AM
WRX-CBR's Avatar
Car Info: 03 WRX
Thanks I'll try that. And it is a sweet smell.
Old Oct 7, 2006 | 05:56 PM
laoba's Avatar
Car Info: rx8
he was right that means coolant and you have a bad head gasket or turbo
Old Oct 8, 2006 | 12:29 PM
meilers's Avatar
Yes, bad head gasket. Our 97 Legacy wagon had smoke just like that; two weeks later the head and cam gaskets failed and I came home to a big puddle of oil under the car. $2100 fix
Old Oct 8, 2006 | 06:15 PM
Car Info: Subaru
How would one know the difference between a bad head gasket and a bad turbo? I have a very similar problem, so I am getting quite concearned.
Old Oct 9, 2006 | 01:00 AM
LifePlaza's Avatar
i'm going to say bad seals on the turbo
