where is fuel cutoff switch for an 04 WRX?
Old Jun 17, 2004 | 05:53 PM
My_Red_Suby's Avatar
Car Info: 2005 Metallic Gray STI
where is fuel cutoff wire for an 04 WRX located?
Hi guys,
I did a research in this thread but I never really found where exactly is the fuel pump or the fuel cutoff wire is located for the 2004 WRX. If anybody knows where its located at, I would appreciate it if you can give me some info. I wanna play around with it to add some security for my car, (Installing the fuel cutoff switch.
Thanks so much.
Old Jun 24, 2004 | 04:30 PM
Nevermind I actually found the fuel pump wiring for my car myself. I just installed my cutoff switch, and it works just fine. Let see if these car thief can break in to my car and try to find it. hahahaha
Old Jun 24, 2004 | 05:59 PM
Rock Strongo's Avatar
Car Info: 2004 WRX Sedan
where did you find that wiring diagram???
Old Jul 13, 2004 | 12:26 AM
InfamousDX's Avatar
Car Info: '03 WRX Sedan
Good idea while you live in NJ but a good thief will know his way around it. If fuel cut comes on when they jump it, they just go to the ECU and rip off the wire that the switch is running too.
Old Jul 14, 2004 | 12:01 AM
jigga's Avatar
Car Info: 02 wrx
One other way is to do what I did.. Have a map on your ecu that causes the car to not run at all...
I have 2 maps on my ecutek-tuned ecu. a good map, and a 'dud' map that causes the car to cut out shortly after it has been started.
The thief had better have a spare ecu or ecutek software to pinch this one!
Old Jul 15, 2004 | 06:39 AM
Egan's Avatar
Don't wire it to the ECU. Either wire it to the fuel pump relay in the passenger kick panel or the controller in the trunk behind the passenger side panel. Just be sure and do a good job of hiding the switch.
Old Jul 16, 2004 | 06:51 PM
Yeah, but do you think a car thief would actually spend some time trying to steal a car. There are few screws to take out just to reach fuel cut-off system and the ecu. It'll work but it'll take too much time for a thief.
Old Jul 16, 2004 | 08:11 PM
InfamousDX's Avatar
Not for thieves in NJ and WRX's/STI's... obviously you haven't noticed the sticky in the tri-state forum about how many of htem have been stolen since late last summer.
Old Jul 18, 2004 | 04:07 PM
you can have more than one map on your ecu with ecutec?
Old Jul 19, 2004 | 07:07 AM
Egan's Avatar
You can, but the second map usually only changes one parameter (boost) due to memory restrictions. That's why you'll see a low boost and high boost "map" with ECUtek reflashes. You switch between the two by flooring the gas pedal (not while the car is running ) and hitting the defogger switch.
It would be awesome to have a daily driver map and a 100 octane track map, but there just isn't the space inside the ECU to accomplish that...yet.
kspek
Feb 14, 2006 05:33 PM
crashnscar
Dec 5, 2005 01:01 PM
ProPain
Jun 14, 2004 10:41 AM
JohnB
Jun 30, 2003 12:14 PM
wiredwrx
Nov 27, 2002 01:47 PM
