where can i find 15.5psi restrictor hose?
Old Jan 11, 2004 | 06:08 AM
minisiu's Avatar
where can i find 15.5psi restricutor hoes?
the oem boost controll by a restrictor hoes, i am wonder can it replace a 15.5 psi retricutor hoes???
Old Jan 11, 2004 | 08:40 AM
Wingless Wonder's Avatar
I fixed your Subject line to say 'hose', because I don't think you are looking for some hoes.
Do you have aftermarket boost control lines on the car now? You can get the factory lines from the dealer but if the restrictor is different in the hoses you're using now, the boost will be different.
Old Jan 11, 2004 | 03:59 PM
minisiu's Avatar
it is a hose, the one connect from t-fitting to turbo. If you take it out and use you mouth to blow it, it restrict air. Well, that 's what i think to keep the stock boost 13.5psi. Because if you replace a wide open hose it only boost 7 psi. So i wonder, does anyone know what i can find a restrictor can only make 15.5psi or 15psi.
Weel, second, I tired MBC it sucks with stock ecu and not safe at all for exsamlpe it took me long long long *** time to adjust the right boost. When i adjusted the right boost and sit my car for few hrs it go back 7 psi. i just scare sometime it over boost so i want to find a safe way to boost my baby
well, boost it fun.... but **** up the engine is not fun.
urusai808
Hawaii Classifieds
Apr 17, 2013 04:58 PM
polyol
Dec 30, 2004 06:16 PM
numbr17
Aug 20, 2004 03:16 PM
RussB
Aug 28, 2003 09:31 AM
100
Dec 1, 2002 03:55 PM
