What's with WRX's?
Old Apr 29, 2003 | 12:41 PM
  #37
ride5000's Avatar
Originally posted by Blacked-Out
And I dont care what anyone tells you here in this forum or about any car, doing mods reduce the life of the car, including intake which cause the car to run lean and brun hotter, theoritacaaly causing more damage to piston rings than usual. If you serious about tuning this car, get an air/fuel ratio monitor, then start bolting on. Also remember, if you lean out with an intake, than richin the mix with a bov, that might not be so bad depending on ratio they are to eachother.
i see some bad advice in here.
a) explain to me how taking the pre-cat out of the up pipe will reduce the life of the car. actually, taking ANY cat out?
b) your point about the cai and the bov offsetting each other is unfounded. the cai is always active--the bov is active when manifold pressure drops due to a closing of the throttle, and will cause a MOMENTARY rich condition. if you have a cai that causes lean conditions and you lean into the throttle hard for a 4th gear pull, that BOV is doing NOTHING and you're nice and lean. watch the damage that results.
remember the issues with CAIs are two-fold:
1) different diameter intake plumbing causes the proportionality programmed into the ECU to be erroneous. the stock MAF does NOT measure all the airflow; it measures a percentage. this percentage is extrapolated by the ECU. if the percentage sampled is changed, you need to change the proportionality of the extrapolation. ie. tune the engine. this is not a design flaw per se in the CAI; it is almost a prerequisite to a higher flowing intake system. if you want to buy a CAI and just bolt it on w/o tuning mods, make sure that the diameter of the MAF region is exactly the same as OEM.
2) badly designed CAIs cause turbulence in the MAF area. this causes erratic and randomly-changing values to be read by the MAF, and is well-neigh IMPOSSIBLE to tune for. watch for bends right before and after the MAF mounting point. don't buy CAIs that have this sort of design... you want the smoothest, most laminar flow possible in this region.
hth
ken gilbert
Old Apr 29, 2003 | 08:57 PM
  #39
ScoobySaurusRex's Avatar
I agree with ride5000
Also, when looking for info on these or any other forums. read a lot, run searches and read everything you find. Over time you will start to see a trend and average opinions or facts about things. You will notice most people tend to agree BOVs are for show and not go and that boost controls can be a bad thing, etc.
Vendor info is good to read up on too. if you can help it avoid vendors that many people have had trouble with. I know it's a lot of information and can be over whelming but a few late night weeks and you'll have a good handle on things.
Old May 1, 2003 | 10:45 AM
  #42
stealth-wrx's Avatar
your problem is xs engineering.
Old May 3, 2003 | 11:49 PM
  #44
turborambler's Avatar
I've been reading these forums for awhile now and figured I'd add my 2 cents. I have a 2002 WRX and have a GFB BOV and a Unifilter CAI. I've had no problems for 9000 miles. My car's an automatic I'm sure someone will rip on that....Anyway I've had a lot of fun with these mods (plus my 17 inch P1's and sti hood scoop) and have noticed no horrorshows. In fact my car was faster with the CAI and hood scoop. To be honest I don't think the BOV did much. I'm getting my UTEC, up-pipe and catback soon. We'll see how it goes.
