Check Engine Light
Old May 3, 2003 | 09:26 PM
wrexr's Avatar
Car Info: E28M5, RAM Powerwagon, Motos
Smile Don't Worry
You are not alone...
I have had the same problem. It is not a fuel issue.
The computer is sensitive. If you allow your car to warm up before driving, even if it is not cold, you will incur less of the CEL's. It typically occurs when the car shutters when letting the clutch out: cold start.
You have probably heard the importance of letting your car cool down some before shutting down. This is why so many turbo owners have turbo timers.
My personal mechanic recommended to me that to prolong the life of my turbo, I should try to let my car warm up and cool down.
The light is annoying, when mine comes on, I pay attention that it continues to run regular. The light will shut off after so many starts. The error is logged in the computer. My buddy at my dealership told me not to worry unless I lose power after 4k rpm. I will post any other info I come accross.
-wrexr
Old May 3, 2003 | 11:16 PM
wrexr's Avatar
Cool down
The cool down should not have any effect on The CEL problem.
It is just a recommendation. From what I have learned about turbos, the cool down allows any oil that is lubricating the turbo to vacate it. Without the cooldown, oil deposits harden, and eventually clog the lines to the turbo= turbo burns out. The warm up I recommend helps to prevent the cold start shutter when letting out the clutch. Alot of people experience better reliability, performance and economy when they ecutek or advance the computer system on the car. Mine will be completed in two weeks. I will post my results on the electronics/cpu forum.
wrexr
Old May 3, 2003 | 11:49 PM
wrexr's Avatar
thanks
Thanks Finn
My mind tends to simplify, I got the concept, and the same results.
I do appreciate the clarification.
wrexr
Old May 4, 2003 | 01:54 AM
Originally posted by The Finn
(This, in the N/A forum )
Due to excessive amounts of turbochargers in this thread it has been moved.
Racerkid
May 29, 2012 06:16 PM
saab92x
Mar 16, 2009 03:16 AM
06scooby
Oct 15, 2006 10:11 AM
rash
May 17, 2003 12:32 PM
