What's with WRX's?
Old Apr 24, 2003 | 11:41 AM
Zoeb2s's Avatar
I <3 White Girls
Originally posted by Silver arrow
If you are really looking for bang for the buck uppipe and downpipe are the way to go.
yup...two of the best mods for your money on a WRX...
Old Apr 24, 2003 | 04:11 PM
driggity's Avatar
Car Info: 2002 Silver WRX Wagon
Re: sure?
Originally posted by burmis1
Well with my Stage one SPO, (Boost Controller (15.5lbs.) and Turboback Exhaust) BOV and Injen Intake, every thing is fine and my air/fuel guage says its good, and when i get on it- its a little rich so don't always beleave what everyone says.
Just Listen.
Just my two cents.
Bryanb
What kind of A/F gauge do you have and what do you mean by "a little rich"?
Old Apr 24, 2003 | 04:43 PM
Ride Operator's Avatar
Car Info: 02 GDA 5spd Silver
Re: 'Milk Jug' silenser removal
Originally posted by DwithBoost
Can anyone tell me where this silenser is located and how to remove it? Also, can I get some feedback on the GFB blow off valve as far as sound, volume, and installation?
This will point you in the right direction, hardest part for me was dealing with the liner...
http://www.scoobymods.com/forums/sho...=&threadid=113
Old Apr 24, 2003 | 05:50 PM
driggity's Avatar
Re: Autometer
When Im cruzin the speed limit its stoich or even, but when i puch it it rises to the rich side, i never seen it go to the lean side, but it should be pretty accurate, I hope, hehe.
yep
Well, considering that most people seem to shoot for under 11:1 at full boost and WOT having a narrowband gauge that says "rich" isn't a very good indicator. You could probably be running 2 points too lean and still have the gauge say you're ok
Old Apr 24, 2003 | 06:52 PM
Br1t1shguy's Avatar
Car Info: 02' WRX
Heres how it works:
You drove a civic which has a naturally aspirated engine (b16)
You are now driving a turbocharged WRX
See the difference? Turbochaged and Naturally aspirated? Different? Two different words, two different approaches too making power, and two completely different bag of worms when it comes time to modify. I dont wanna bother to explain exactly why but essentially factory turbocharged car requires twice as many sensors, has twice as many variables being controlled by the ECU, and as such is twice as sensitive to any modification.
In the future research the things you put on you're car instead of piecing it together like a leggo toy and hoping the hodge-podge collection of mods work together.
If you ever want to have a really fast car, not another randomly modified wanna be rice-rocket, you have to set some goals for what you want to do. How much power do i want to make? Where will my powerband be? How can I get there? From there you can pick and choose parts that will work together (IE does this IM plenum size work with this cam profile?). If you come across something you dont understand you research it and figure it out. It's called building an engine package, because the only way to make real and reliable power is to pick parts to work together as a package. This is what sets apart the Super Street ricers from the guys that actually go out and build the cars in the magazines...
Old Apr 25, 2003 | 02:17 PM
EvoEater's Avatar
Car Info: 03 WRX silver
keep your cai on the car and get a full turbo back exhaust. Having just a cai lets more air in than the stock exhaust can let back out, like the guy before me said, "work things together as a package." Apart they dont do much, but both together does alot.
Old Apr 25, 2003 | 08:46 PM
ScoobySaurusRex's Avatar
I believe it has something to do with the turbulence created by the CAI, the MAF doesn't read correctly and may allow more air to pass un-messured. Someone correct if im wrong.
I understand why the bov would cause problems but why would the intake cause me to run lean? What is the difference between the air box and my intake besides larger quantities of air? The mass airflow sensor will read more air and then put in more fuel to compensate. Also both the intake and the air box take air from out of the fender. What is the problem? Does anyone have solid proof (with gauges or such) that intakes make your WRX run lean?
