what's wrong with my car?
Old Oct 7, 2003 | 06:17 PM
Subi114's Avatar
Car Info: 04 WRX JBP
Question what's wrong with my car?
Okay I just got this 04 rex and now everytime I'm idling I feel more vibration from the motor. It has 1600+ miles on it now. I don't know if I'm trippin or if something is wrong. Also when I'm driving and shifting to 2nd it feels like it's boggin. It's really not that noticeable but to me it is. It only happens sometimes. It also does it on 3rd. It's between 2k-3k rpm when it does this. What do you guys think? Also when I start my car the RPM needle shoots up to like 2.5k and drops down close to 0 and rises slow to 500. does anyone else experience this... Sorry for all the questions. I just wanna know if my baby is sick and need to take her in.
Old Oct 7, 2003 | 06:57 PM
Subi114's Avatar
can someone pls help... I really need to hear from you guys if i'm just trippin or something is wrong with my car.
Old Oct 7, 2003 | 07:05 PM
Doesn't sound like there's really anything wrong. Stock USDM EJ20s are not so good below 3k rpm.
Old Oct 7, 2003 | 08:12 PM
WRX Rush's Avatar
Car Info: Stage 4+ Bugeye
Stock 2003's spool at like 3400 RPM's and under that they bog huge. I'm sure its a case of under shifting on the new car. Its ok it happens to everyone. Good Luck.
WRX Rush
Old Oct 7, 2003 | 10:44 PM
zunus's Avatar
Sometimes I notice the idle vibration more than others, but its just the boxer engine. I posted the same question on here about my 2003 when I got it, or someone else posted it but I was thinking it.
Old Nov 3, 2003 | 11:40 PM
EZ Rider's Avatar
Car Info: '02 Legacy GT - no mods
Also if you're using the AC or defogger it can make it seem like the engine is vibrating more. But it's fine.
Old Nov 4, 2003 | 12:59 AM
international B's Avatar
Chewwwwy
check all your vacum lines, do you have a check engine light on? could be a loose wire to the MAF sensor. (sensor on the intake box) do you have a aftermarket intake?
good luck
Old Nov 4, 2003 | 06:26 AM
ScoobyStas's Avatar
Car Info: Sonic Yellow WRX
when my starts the needle goes t0 1500 rpm and slowly tapers to 500rpm when it's fully warmed up. You should get it checked out. My car has never shot to 2500 and then to 0rpm. Sounds wierd. Your car is probably still stock, so don't hesistate and bring her to the dealer.
Old Nov 8, 2003 | 10:38 AM
Subi114's Avatar
thanks guys i'm gonna bring it to the dealership as sson as I have the time.
Old Nov 8, 2003 | 01:34 PM
Uncle Scotty's Avatar
I've found that some gasoline brands make for a more stable idle than others. So maybe try different gas...You ARE using premium fuel, right?
Old Nov 8, 2003 | 03:21 PM
Max Xevious's Avatar
BanHammer™
Car Info: 2014 Forester XT
did you check the lines to your two big bottles ?
Old Nov 9, 2003 | 11:14 PM
DarkAngel's Avatar
:banana: :banana:
Old Nov 10, 2003 | 07:04 AM
capa-don's Avatar
Car Info: two thousand four - java
i have an 2004 as well and mine never did the whole 2500-0 thing early.. actually the post above describes how my car has been from 15 miles (when i got it) to its present state at 10,500mi... take it to the dealer.. something is wrong (and remove all noticeable mods first)
BTW - im in jerZ so i have the option for sunoco ultra 94 for street use (only $1.69/gal here)..
check yo octane f00 :banana:
Old Nov 10, 2003 | 12:34 PM
downshift's Avatar
Car Info: dream car Subaru STi
engine vibrations are normal, ur car is mean and loud, if u get n exhaust u will notice the sounds n vibrations more, thats how the wrx is, its mean and powerful, sounds like u arent shifting too well, u might still be new in the manual tranny cars, just keep practicing shifting cause if u dont shift correctly and dont add enough gas ur car will bog. shifiting takes skills and finese.
ChuiSti
Aug 5, 2005 06:30 PM
Scoober02
Nov 24, 2004 03:25 PM
spankaveli
Feb 24, 2004 06:04 PM
LUV2XLR8
Nov 23, 2003 01:51 PM
02silversuby
16
Oct 28, 2003 01:36 PM
