what's wrong with my boost controler??
Old Jun 30, 2004 | 12:42 PM
.:: 808 STi ::.'s Avatar
Car Info: "the loud one"
ok...i just installed a Blitz dual-sbc spec-R boost controler into my car...but when i try to turn up the boost, the max boost i do push is about 8-9psi...can anyone help me...i installed it just the way the instruction book said to install it...but what's wrong with it?...
Old Jul 5, 2004 | 06:01 PM
no one?
Old Jul 5, 2004 | 11:39 PM
boloheadrat's Avatar
Did you take the advice I gave you in the Hawaii forums?
Old Jul 5, 2004 | 11:42 PM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
Looks like you have connected the vaccum lines incorrectly. You are running your spring pressure.
Old Jul 6, 2004 | 09:50 AM
platypus's Avatar
Car Info: dangerous with a wrench
You might actually want to have someone check on the restrictor in the vacuum line. I had a similar situation where I was unable to top 10psi. Gino from GB checked the restrictor and it had gotten banged, and was out of shape. A simple tweak with a pair of needlenose pliers, and voila, plenty of boost on tap.
Old Jul 6, 2004 | 04:13 PM
Actually, I believe he was using the large hose supplied in the EBC kit--it is perfect for the solenoid, but way to big for the turbo and wastgate nipple. I bet he's leaking pressure from these spots. 808, either get a hose reducer (you can use the ones off of the stock hoses) or just use a smaller hose all the way around.
Old Jul 7, 2004 | 03:43 PM
RussB's Avatar
Car Info: $200,000 sports car
a leak in either of those locations would result in excessively HIGH boost.
.:: 808 STi ::.
Jul 1, 2004 11:54 PM
.:: 808 STi ::.
Feb 16, 2004 11:43 AM
DWNSHFT
Dec 7, 2003 02:02 AM
RBREX
Oct 1, 2003 03:59 PM
digitalroojp
Jan 13, 2003 03:49 PM
