What Turbo Does Subaru Use
Old Sep 21, 2005 | 10:43 AM
sylencce's Avatar
Car Info: 04' WRX Silver Scooby
Does anyone know what brand turbo subaru put in the 04 WRX?
Old Sep 21, 2005 | 10:48 AM
soggynoodles's Avatar
They use a TD04 turbo. I believe Mitsubishi makes them.
Old Sep 21, 2005 | 10:55 AM
sylencce's Avatar
Thanks for the help!! You wouldn't happen to have the specs on it would you? FOr max boost it can handle...etc...??? Or know where I can find the info on it? I did a quick search on-line, but came back with like 3,000 websites!!
Old Sep 23, 2005 | 03:10 PM
SubieGears's Avatar
Car Info: '02 WRX PSM
It is a Mitsubishi turbo, but I don't know the exact flow specs, etc. The bypass valve (on my '02 WRX for sure), is also from a first gen. Eclipse/Talon. Mitsu really knows their turbo stuff. But not much else.
Old Sep 23, 2005 | 05:04 PM
xenophobe2020's Avatar
search on here for max boost, youll find plenty of topics.
Old Sep 25, 2005 | 09:12 AM
MO REX's Avatar
Car Info: 02 PSM WRX
It’s a Mitsu TD04 13T and from what I’ve read you don’t want to push it over 17 psi (not sure though). I have a 02 stage 2 with 85K, I’ve been pushing 16 psi for around 30K and the oil seals on the turbo are going bad.
Try doing a google or yahoo search, type TD04 13T and you should be able to get a better answer.
Old Sep 25, 2005 | 09:18 AM
1reguL8NSTi's Avatar
Car Info: 05 STi
For reliability issues you don't want to push them too hard but I've seen stock WRXs running far in excessive of 17lbs.
Old Sep 25, 2005 | 12:30 PM
MO REX's Avatar
If you run a TD04 13T far in excessive of 17lbs you will be blowing a lot of hot air. Hot air not only hurts reliability it also kills performance.
Old Sep 25, 2005 | 12:33 PM
Car Info: 05 STi
haha I do agree with you there and although that car may not have lasted too long (he traded it on for an STi so I'll never know) but it ran like a scalded dog. Faster than a stock STi for sure.
Old Sep 28, 2005 | 04:42 PM
Donkey's Avatar
Car Info: 02' WRX
The 13T roughly puts up 390cfm @ 14.5psi. Just a little more than the 13G pumping 360cfm @ 14.5 psi.
Greg Davis
Sep 22, 2004 02:15 PM
KMount
Dec 18, 2003 04:18 PM
davenow
New England
Dec 19, 2002 08:28 AM
live311
Dec 9, 2002 10:42 AM
