View Poll Results: what should i get
gt spec header
0%
vf22 turbo
91.67%
nx n-cool n20 spray
8.33%
Voters: 12. You may not vote on this poll
what should i get
Old May 4, 2004 | 12:43 PM
Ditty77's Avatar
Car Info: 2002 WRX
always go with turbo
Old May 4, 2004 | 01:34 PM
MonkeyAB's Avatar
Car Info: 2001 Impreza 2.5RS(Ti)
I vote none of the above. I am an engine management ****, so I vote for that. Get a dyno tune. If you've already done that, then go with the turbo.
Old May 5, 2004 | 10:42 PM
scoobykid04's Avatar
Car Info: 04 SUBARU WRX SEDAN
The real question is, how big are you trying togo? If you go with a turbo upgrade its going to run you alot of money to do the upgrade correctly, like fuel, engine management, turbo, intercooler, and maybe even a stronger clutch......If you dont wanna go that big, you might find that a ecu reflash or piggy back system will satisfy you...
Old May 5, 2004 | 11:46 PM
DLUX WRX's Avatar
i would have to say that it would be a smart idea to get some type of engine management next. you can extract some more power out of your current set up. if you were to get the turbo, then you would have to get injectors and a fuel pump. on top of that you would need some engine management to set it all up properly. if you dont want to spend a ton of money right now, get the ECU upgrade ( reflash, piggy back, accesport etc...)
Old May 8, 2004 | 10:59 AM
9hotmailk8coupe's Avatar
Go with the turbo. 20g
Ridoan
Sep 8, 2009 11:40 PM
dr3d1zzl3
Aug 20, 2004 03:19 PM
JZa80GTRHybrid
Dec 28, 2002 09:35 AM
Mach5WRX
Nov 25, 2002 10:03 AM
