What oil weight?
Car Info: 72 Vespa with curb feelers
Originally Posted by Dm0n3y002
I live in michigan and its starting to get pretty cold so i was wondering if i should change the weight ive been using? All summer i was using mobil 1 5W30, should i use something differant for the winter?
I'm lucky. I can run straight 40 all year where I live. =)
Origami posted by Dm0n3y002
You didn't mention how cold it gets in your part of Michigan but Subaru recommends a multi-viscosity 5W-30 weight motor oil from sub-zero temperatures up to 100 degrees F. The reason why they prefer a multi-weight oil is for better cold-start characteristics and slightly better fuel economy. Mobil 1 5W-30 is one of those motor oils rated as "Energy Conserving". My fuel economy is pretty good for a WRX but it's probably related more to the way I drive while commuting through traffic.
I use Mobil 1 5W-30 in my WRX all year 'round. Winters are mild, rarely go below the freezing point but summers can easily reach or exceed 100 degrees. I have faith that a decent, off-the-shelf synthetic can still provide protection in hot weather unless I'm tracking the car under those conditions. In that event, I might switch to a different weight of Mobil 1 or other synthetic (or just avoid going to the track because it's too damned hot with the windows rolled down!).
topdog
17
Mar 31, 2007 02:16 PM
chrisok5
Aug 29, 2005 10:14 AM
wrxless
16
Apr 27, 2004 08:39 AM
