What MODS next?
Old Jul 27, 2003 | 03:34 PM
The UTEC doesn't haev a whole lot to work with on basically a stock car. Get and uppipe, downpipe, and exhaust, retune, and you'll be amazed.
S-Squared Motorsports sells an excellent uppipe with EGT bung, flex joint and heat shield for $225.
Replacing your downpipe is necessary due to the horrible flange design of the stock piece. However, finding one with a high-flow cat is difficult and expensive. Catless downpipes are illegal in all 50 states. The only reason to go with a catless one is because you need to run leaded race gas due to humongous power needs.
Any 2.5"-3" catback exhaust will do the trick as long as it has a straight-through type muffler. Anything from $300 custom with a Magnaflow muffler up to Vichnu's $1200 all-stainless unit do about the same thing. Choose mostly based on the sound and look you want.
And that's about it for now. Get that stuff, find a good tuner, and you will be very pleased. For a while.
Old Jul 27, 2003 | 04:40 PM
Max Xevious's Avatar
BanHammer™
Car Info: 2014 Forester XT
thanks for the plug kevin
I got 1 word for you ---> NNNNAAAAWWWWSSS !!
but be carefull, if your not a pro, you will kill yourself with it
Old Jul 27, 2003 | 05:30 PM
Try posting in your regional forum. that's why they are there- to provide a place for people to share info like that. We can give you technical advice and answers, but only locals can tell you where to get struts installed or an alignnment done or where to get high octane.
Old Jul 27, 2003 | 06:49 PM
To be honest, I would suggest reading the manual and tweaking it (slowly) yourself. If it is running really well, no hiccups or bogging, the hard part is done. Now you can tweak it by bumping a little bit of advance 1 or 2 degrees at a time, cutting just a little bit of fuel there, adding just a little there... just be careful. If the UTEC doesn't do it, I'd recommend getting a J&S Safeguard.
Old Jul 27, 2003 | 07:04 PM
A J&S Safeguard uses a very good knock sensor to monitor the engine and retard timing if needed. The best part is that it tells you when it is, so you can tweak that part of the map to get rid of it, instead of constantly just relying on the J&S. It's good to have, I plan to use one. Right now, my "setup" is an '01 RS with intake and full exhaust.
As for your next mods, go with the up and down pipes and catback, but don't worry about your intercooler yet. It's got plenty of room to grow for now.
Old Jul 27, 2003 | 07:31 PM
davenow's Avatar
FIrst things first, Get an up pipe.
Then a full turbo back exh.
TurboXS stealthback, with a high flow cat is available for under 700, and is VERY stealth, as you use your stock muffler.
I paid 590 for mine, because I choose to go completly catless and free up every HP I can.
Up pipe should be the very first mod you do power wise.
Old Jul 27, 2003 | 09:05 PM
BanHammer™
Just always remember when you are tuning !
Lean is mean, but Fat is where its at !
kyoung05
Oct 19, 2009 09:11 PM
darkonion
May 7, 2007 01:57 AM
BoxerRumble
Sep 15, 2004 08:50 AM
1/500yellowwrx
22
Mar 1, 2004 06:59 PM
turborambler
Feb 28, 2003 07:19 AM
