What does your boost gauge read when...
Old Jan 12, 2004 | 11:32 AM
frisco-wrx-dude's Avatar
Car Info: '04 Silver WRX
Hey there
Quick question
What does ur boost gauge read when ur at "idle" and when ur off the gas/throttle pedal when cruising on the highway. (i know you should be in vaccum, but what vaccum psi are you at?)
I just want know to do some comparison.
So far, for me, i'm hitting (during idle) around -15psi or so and a lil over -20psi when cruising on the highway when off the pedal.
Old Jan 12, 2004 | 11:43 AM
Salty's Avatar
Re: What does your boost gauge read when...
Originally posted by frisco-wrx-dude
Hey there
Quick question
Sounds a bit low. Try unconnecting the neg terminal on the battery to reset it and see if it changes. I should be at a vacuum but i don't think that low. Does it go back to "0" when you turn off the car or does it set at around 5-10 mmHg?
EDIT: mine is at about 16 mmhg at neutral and at about 13 mmhg in gear.
Old Jan 12, 2004 | 12:10 PM
RussB's Avatar
Car Info: $200,000 sports car
same here. -15 mmHg at idle, -20mmHg when decellerating.
Old Jan 12, 2004 | 08:55 PM
cool, i thought something mighta been wrong, cuz I swore that it wasn't that low, but maybe it is..
Thanks guys
Old Jan 13, 2004 | 10:57 PM
Kean's Avatar
Car Info: 03 WRX / 08 Forester
Frisco, If your gauge reads PSI (positive pressure; above "0"), then it most likely reads in InHg - inches of mercury (vaccuum; below "0") and not mmHg. .......most likely.
Mine reads in PSI/InHg and is similar to the readings you get (I'll have to check). Obviously, various conditions will affect your readings (engine load, altitude, etc).
- Kean
Old Jan 14, 2004 | 11:54 PM
DanZ's Avatar
Car Info: 2002 MBP WRX
Which boost gauges do you guys have? I have a Blitz and it reads -.59-(-.63) bars at Ilde. Does that make sense? Is it the same as mmHg? Numbers seem way different. Can someone please explain? Thanks, Dan
Old Jan 15, 2004 | 12:27 PM
Kean's Avatar
Originally posted by DanZ
Which boost gauges do you guys have? I have a Blitz and it reads -.59-(-.63) bars at idle. Does that make sense? Is it the same as mmHg? Numbers seem way different. Can someone please explain? Thanks, Dan
Personally, I have Omori gauges that read in Imperial measurements: PSI (for pressure) and InHg (for vacuum). It looks as though your gauge in fact reads in "bar" for both pressure and vacuum. If so, -.59 to -.63 would be equal to 17.4 to 18.6 InHg (inches of mercury). ........this is normal.
- Kean
Old Jan 15, 2004 | 12:39 PM
gilmore25's Avatar
Car Info: 05 LegacyGT,06 Black STI Will be home Soon
on cold starts it usually stays at -.06 and when warmed up it idles at -.07 and usually stays there when i'am on idle, when coming off the gas it's almost at -.1 bar
Old Jan 15, 2004 | 12:44 PM
Kean's Avatar
Originally posted by Nesquik
I am not sure what the correct pressures should be but:
1 bar = 14.5 ~ 14.7 psi (I think it's 14.7 (atmospheric pressure))
1 bar = 760 mmHg (I think)
1 psi = 51.7 mmHg
So,
-0.59 bar = -8.5 psi , - 442.5 mmHg?
Do the mmHg gauges read in hundredths or something?
Close enough.....
1 bar = 14.5 PSI
1 bar = 750.1 mmHg
The gauges that I've seen that read in mmHg for vacuum will display actual #'s (i.e. 500, 700, etc), and some other measurement for positive pressure (i.e. bar). It all depends on the manufacturer and what type of measurement they decide to go with.
- Kean
Old Jan 15, 2004 | 12:52 PM
Ditty77's Avatar
Car Info: 2002 WRX
Someone needs to post a chart.....
I can't find mine.
Old Jan 15, 2004 | 01:29 PM
Kean's Avatar
Use this nifty tool:
http://www.joshmadison.com/software/convert/dl.asp
Old Jan 15, 2004 | 02:16 PM
Salty's Avatar
another great url that deals with every conversion known to man.
http://www.onlineconversion.com/
Old Jan 15, 2004 | 07:45 PM
DanZ's Avatar
Thanks Kean and everyone else.
-Dan
04GG
Jan 30, 2012 02:17 PM
cdawg
Jan 4, 2008 03:44 PM
My_Red_Suby
Oct 21, 2005 01:54 PM
Rat
Feb 19, 2004 06:45 PM
mattr762
Apr 18, 2003 09:12 AM
