weird noises
Old Feb 27, 2007 | 06:13 PM
hiroaki's Avatar
Car Info: 2004 WRX...
weird noises
I need some help. I have a 2004 wrx and everytime I make a sharp turn, my car makes a katonk noise? Does anyone know where this is coming from? Or had the same problem? I recently changed only one tire on the front drive shaft and the other tire has about 60% tread left, could this be causing the noise? I have cusco zero 2r coilovers on sti wheels. Help me out please.
Old Feb 27, 2007 | 06:55 PM
mgb04's Avatar
Car Info: 04 STI, 03 M3, 08 335i, 15 i3
i don't think the tires would be making the clanking noise, though it's always suggested that you replace all tires instead of changing one.
are your strut tops torqued down to factory spec? i believe it's ~14lbs on the three nuts.
also, have you done anything with your swaybars? i was experiencing a weird clunk noise whenever i made right turns, and it turned out that one of the nuts on my rear endlink had come loose. i swapped out my endlinks and some new nylock nuts, no more clunk .
Old Feb 27, 2007 | 08:06 PM
hiroaki's Avatar
thanks for the help mgb04
Old Mar 3, 2007 | 08:47 AM
pwn's Avatar
pwn
Car Info: 09 STi, 10 Cayman S
From what I have read on the forums, changing one tire is REALLY not good for your car, especially on AWD vehicles. Maybe I'm just blowing hot air, but someone else chime in?
Old Mar 3, 2007 | 08:57 PM
hiroaki's Avatar
Problem fixed. Tightened my strut tower bar to tight and the bolts cracked.
Old Mar 20, 2007 | 09:45 PM
mgb04's Avatar
glad you got that fixed
935BlueWRX
Nov 27, 2010 04:02 PM
ARisso916
Mar 18, 2010 05:00 PM
dSpec
Sep 17, 2006 09:47 PM
thsiao
25
Nov 23, 2004 10:58 PM
