Weird injector problem...
Old Jul 15, 2005 | 08:15 PM
Imprezer's Avatar
Admin v2.0
Car Info: 02 Black Legacy GT
So I am trying to get my car dialed in for the Hammy meet. Here is what is happening.
The car runs on 2-cylinders. Runs well and sounds almost normal. Only the back cylinders are working (3 and 4). I have spark on all 4. Injectors are not firing on 1 and 2.
When I disconnect either one of the rear cylinder injectors, the front ones (1 and 2) start working.
So, as is, with every injector harness plugged in, the car only fires injector 3 and 4. if I disconnect 3, then 1, 2 and 4 are firing. If I disconnect 4, then 1, 2 and 3 are firing.
What gives?
The car is a 02 WRX with SPEC C motor and ECU.
Old Jul 16, 2005 | 12:00 AM
DLUX WRX's Avatar
damn, sounds like its possesed. wish i could help.
hope it works out alex.
Old Jul 16, 2005 | 12:17 AM
have you switched injectors for small stock ones?
have you rotated all the injectors?
Old Jul 16, 2005 | 01:40 AM
Krinkov's Avatar
wow, are you getting a different voltage from the injectors when 2 fire then when 3 fire? have you ohm'ed out all the grounds? Also, if you have just 3-4 plugged in can you get either 1 or 2 to fire if you unplug either one? just tryingt o isolate if it has to do specifically with 3-4 or if you can just run any 3 injectors at once. If the voltage stays the same when its running 2 or 3 and you ohm out even on all leads I would try another ECU, Mike has a couple
Old Jul 18, 2005 | 05:30 PM
Imprezer's Avatar
Admin v2.0
Ok, I figured it out. Funky yet exciting...
I knew that everything (injectors, all sensors and stuff) had one common ground. However, I did not know that not having something plugged in would cause a sporadic ground. In my case, since I am using a Mustang 75mm throttle body, I was not using the OEM idle control motor. I guess the idle control motor is a pass through circuit so when it was disconnected, there was a “bad” ground so the 1 and 2 injectors would shut off.
Go figure. Since I converted from TEC III, this whole stock ECU thing is totally new to me...
Old Jul 18, 2005 | 06:22 PM
Krinkov's Avatar
umm, yeah, that was gonna be my second suggestion,
Old Jul 20, 2005 | 10:40 AM
Imprezer's Avatar
Admin v2.0
Now I want to find out if this is the case only on my car or if all WRX's do that...
TonySinclair
Mar 27, 2008 11:49 AM
slow04wrx
Apr 25, 2005 11:21 PM
ThrilRyder
Apr 12, 2004 08:41 AM
razorlab
Apr 3, 2004 01:15 PM
