BEST OIL TO USE for my03wrx
Old Jul 12, 2005 | 03:10 PM
DWNSHFT's Avatar
Car Info: 03 sedan 2nd wrx
Hey I'm doing my own 30k service I'm changing my motor oil w/ mobil1 5/30
and buying oem fuel filter, oil filter, and crush washer. But as for my tranny and frnt & rear diff. what is the BEST oil brand and wieght I can use. I dont race the car too much but do drive hard once in a while. As for radiator I will use 1 or 2 water weters but what anti freez do I use. should I buy the subaru one or something eles. what? thanks for the help
Old Jul 12, 2005 | 03:39 PM
kumaWRX's Avatar
Car Info: 04 Toyota Tacoma
Mobil1 isn't the best motor oil. Amsoil is a much better oil as it is a true full-synthetic, Mobil1 isn't. Mobil1 still uses petroleum, while Amsoil is fully man-made.
Old Jul 20, 2005 | 05:30 PM
GasPipe DreameR's Avatar
Car Info: lowered blk04 with no motor
i use castrol gtx 5w30
Old Jul 20, 2005 | 06:03 PM
xenophobe2020's Avatar
its called search oil, i hear its the best.
Old Jul 20, 2005 | 07:20 PM
HellaDumb's Avatar
Car Info: 72 Vespa with curb feelers
Personally, I'd run 10/30 Mobil 1 unless you plan on going to Alaska.
Regular 80/90 valvoline in the tranny and diff is fine, since that's what the synchros and limited slip are designed for.
To avoid corrosion, make sure you use an equal portion of distilled water and subaru or honda antifreeze/anti-boil, and add one Subaru cooling system conditioner (stop-leak)... they started recommending this as some WRXs develop minor coolant seepage at the head gasket and/or radiator tanks.
huck
Aug 23, 2017 02:18 PM
b3atbxr
Aug 9, 2007 12:13 PM
DWNSHFT
Jul 21, 2005 02:45 PM
SUB-ZERO
14
Jan 26, 2004 04:12 PM
tad
Apr 26, 2003 12:50 PM
