Want boost gauge and MBC for < $250
Need a bit help..
Hi guys,
I have about 200 dollars to spend, and I just want to know what good Boost Controller and Turbo Gauge I can get with about 250 (MAX) dollars I can spend. I have searched and really not found what I was looking for.
Thanks!
Thanks!
I'd like to suggest an ECU reflash to take advantage of your mods. Cobb AccessECU is less expensive than EcuTek but both will work. You might want a custom tune if you elect to keep that CAI.
A reflash tailored to your mods is a safer way to go than just a boost controller and no engine management.
Car Info: $200,000 sports car
Originally posted by jonik
Sorry for the title Wingless Wonder, as for the re-flash sorry I forgot to mentioned that I have a Cobb Re-Flash with AccessECU port lined up in 3 weeks.
if u are getting the accessecu in 3 weeks why not save the money on the mbc and just wait it out? Must be a big baller :banana:
Originally posted by RussB
the boost gauge you should be able to find just about anywhere for $250. if you're getting a cobb AccessECU in 3 weeks, then why the MBC? you'll just have to take it off when you install the ECU.
Car Info: 2002 MBP saloon
I just wanted to know how much the installation for the Turbo Gauges cost... Lets say on the left hand side of the drivers side pillars.
Originally posted by subawho?
dude the boost gauge install is cake...Took a noob like me ~45min. from start to end....make sure you get a good fitting pod. I heard autometer makes the best fitting ones, but you'd have to paint it light gray to match the interior....I got a gaugepods.com pod and it fit "ok" not the best, but it was painted already. Scoobymods has many boost gauge installation directions.
Alright thanks alot man.
FuturistiK_STI
Jun 30, 2011 08:45 AM
cdawg
Jan 4, 2008 03:44 PM
GottaREX
Jun 17, 2004 09:30 AM
mattr762
Apr 18, 2003 09:12 AM
